Quote:
The transmission (not transfer case) prefers to be filled on the high side versus low side. If you have a cold transmission and you are slightly underfilled, then it is fairly common to have the jerkiness you are describing. I recommend you top off the transmission fluid (you might only need half a liter), filling it at the 35 degree temp set point.Originally Posted by honerboys
i have always noticed a jerk when starting from a stop but only once and only when car is first used for the day - when i purchased it (private sale) the PO gave me an invoice from a local porsche dealer for a replacement of the transfer case in january 2020 - i looked under the car and the date of manufacture is 8/19 - this date is on the cover of the electrical box on TC - so i assume it was done and has the new improved TC - i took it back to dealer who did replacement and they couldn't find a problem - it's not really a big issue and i'm not sure it's even the TC - should i take to a different dealer to check - would this still be under extended warranty (car was put into service 2012)
Also, the software version 1150 on the control unit indicates you have the newer reinforced transfer box that has not been shown to have the same issues as the prior versions.
r553 - yes i did the transfer case fluid change 3 months ago ...no change - garrett376 - hmmm..that makes me think - i changed the transmission fluid and filter about 6 months ago - i tried to put back in exactly what i took out and it was dripping out the fill when i sealed it up - old school used to be you NEVER overfilled an auto transmission or it would develop leaks, so i do tend to go on the less is better side - i'll try adding a half liter and report back here
Quote:
It's not that you are overfilling it; it's that people tend to underfill these boxes and get hesitations that are remedied with proper filling. A drip at 45 degrees is underfilled; a stream at 35 degrees is what you should shoot for.Originally Posted by honerboys
I have a 958.2 Turbo with 36,000 miles and has had two TC replaced. What is annoying to me is the response delay when you step on the gas hard and the car finally decides to move. I have tried other ZF’s 8 speeds on other SUV’s and for some reason the one on mine feels ancient technology compared to newer cars. Might be just programming, or is the TC design as well?
Guys i got a question , 3 Weeks ago I purchased a 2012 Cayenne base with 97k miles , I only put 500 miles but having issues with the transfer case i belive , I went to porsche dealership 3 days ago but i unfortunately my tc warranty expired on 10/20/21.Is there anything that i can do about that ? The service manager told me that i can contact with porsche usa support he even gave me phone number but they are super rude and careless,The lady over the phone said if it is out warranty they cant do anything and hang up.
Quote:
create a profile on Porsche website. Add your car to it. Submit a request via website describing your situation. Be specific about referencing extended warranty on the TC and asking to open a case for "goodwill repair". Originally Posted by durukan_al
right now everybody is on holiday and whoever is manning the phones are not the right people.
Just sent the porsche USA an email about it .Thanks a lot
Simeon
close
- Join DateDec 2021
- LocationChicago, IL
Liked:217 Times in 151 Posts
Hey guys, I saw you were trying to keep a list of diagnosed transfer case issues. I just had a 2017 CS w/ 48k miles diagnosed with bad transfer case. I have scheduled to take in for the repair in a couple of weeks and I feel like it's getting worse by the day.
Quote:
what are the symptoms you experience ?Originally Posted by Simeon
Simeon
close
- Join DateDec 2021
Not sure what the correct vocabulary is to describe it. I would describe it as a pulsating acceleration in second and third gear. It just doesn't accelerate smoothly and I could feel a repetitive slipping that if didn't know was the transfer case would think is in the transmission.
Another thing I could see and hear is that second and third gear almost engage in two steps - on upshifts to second and third, the engine rpms first drop a to about half way to where they should be when fully engaged, hover there for a second or two, and then fully drop down to where the gear is fully engaged.
And importantly, all of these symptoms only start to appear after the transfer case has a chance to get close to full operating temperature. So if it's cold outside, you may need to drive around for 15 - 20 minutes before you start to feel it.
Quote:
This is the normal transmission shifting behavior.Originally Posted by Simeon
Another thing I could see and hear is that second and third gear almost engage in two steps - on upshifts to second and third, the engine rpms first drop a to about half way to where they should be when fully engaged, hover there for a second or two, and then fully drop down to where the gear is fully engaged.Quote:
This sounds like transfer case to me. I remember the same sensation and thought mine was misfiring. Took it to Porsche and it was the transfer case.Originally Posted by Simeon
They might goodwill that repair as it is a known issue especially if it has been done once already on your Cayenne.
