Sponsored By:
Sponsored By:
Transfer case
Old Feb 20, 2018 | 10:06 PM
  #376
deilenberger's Avatar
deilenberger
Originally Posted by ndx
Hi Guys
What is the verdict on fluid ? Is ravenol still way to go?
Thx
Maybe - but at this point - I'd only use genuine Porsche (or perhaps the Shell oil discussed earlier - which appears to be where Porsche gets their oil from.) The Ravenol bottle is killer for filling it though.. so it's worth saving the bottle (I did..)
And - there is about $10 difference between Ravenol and the Porsche fluid (Porsche dropped the price).. so why Ravenol?
Old Feb 21, 2018 | 10:45 AM
  #377
quickster2's Avatar
quickster2
Default Pics
Here are some pics of X-fer case apart.
Old Feb 21, 2018 | 11:51 AM
  #378
deilenberger
Quickster - remind me - what was your problem with the TC? And what did you try to fix it? BTW - wonderful pics, I might resize them a bit for you - they're a tiny bit on the large size
What's interesting is:
So we know it's made in Germany now - and can guess it's ZF or Getrag.. (the two big transmission makers in Germany.) The transmission itself is supposed to be a ZF - so I'm gonna guess so is the transfer case.
CORRECTION: 04/10/18 - In looking at used 958 Cayenne transmissions on eBay it becomes obvious that the transmission is made by Aisin, in Japan.
Old Feb 21, 2018 | 12:23 PM
  #379
quickster2's Avatar
quickster2
Please take all of the editorial liberty you want with the pics. I have more but these should suffice. The reason I took the case apart was to weld the crack at the drain hole. Coming from my aviation background I was not going to be satisfied with JB weld or some similar repair method.
As noted in the pictures the PO had the case replaced at some time earlier with the -08 revised one. I suspect that the case was replaced because they ran over something. I don't know for sure as I bought my PiG from an independent dealer. Regardless, my case failed due to the driveshaft coming out of the rear differential and before I could safely pull over to get out of traffic (only a few hundred yards) my case was literally smoked. This accelerated wear to failure happens as the clutches were trying to engage based on stepper motor input. My nearly fresh oil was black after this event. This "event" combined with the bent X-fer case cross member and bracket as well as a compromised rubber isolater in the cross member lead to premature wear on the case due to poor alignment as well (my thoughts). I assume it was going to fail soon anyway based on the difference in drive-ability immediately noticed with all of the repairs accomplished. This is the only plausible explanation we came up with. So......frame repair, new cross member, new case, new hardware all is back to like new condition.
I've now put several hundred miles post repair and I cannot believe how much nicer the vehicle shifts, accelerates, and decelerates.
Old Feb 21, 2018 | 09:41 PM
  #380
e30rapidic's Avatar
e30rapidic
awesome! Thanks quickster
Old Feb 21, 2018 | 11:02 PM
  #381
ndx's Avatar
ndx
I will be rebuilding mine ... I'm just trying to track info on the programming part after rebuild ... I do have access to Piwis 2 so its not a problem, but I need to know procedure. ( Some procedures like pinging fix require special values that have to be inputted )
Old Feb 22, 2018 | 11:34 AM
  #382
CAVU's Avatar
CAVU
I spoke with my dealer's part lead about the various part numbers I had seen on my receipts related to my last two transfer cases. Here is what I learned:
Serviced Jan 2017
958-341-010-HX Current version as of my service date.
958-341-010-HU the "U" at the end is how the designate a used part that is coming out of the vehicle
Serviced 1/2018
958-341-011-EX New version effective Feb 2017
958-341-011-EU The "U"sed Core.
The car was in to have the vent kit installed because they did not install it back in Jan 2017. Porsche had communicated back in Oct of 2016 to install the vent.
Old Feb 22, 2018 | 04:57 PM
  #383
CarGuyNVA's Avatar
CarGuyNVA
Looks right, mine was replaced in April 2017 and this is the version they installed (along with the vent kit, etc.).
Old Feb 23, 2018 | 01:36 AM
  #384
deilenberger
Please do consider a DIY while you do it. If you take the photos whilst doing it, I'll be glad to help put the rest of it together. It would be a really great contribution to the community knowledge.
Old Feb 23, 2018 | 12:04 PM
  #385
ndx's Avatar
ndx
Im planning to record video ...
​​​​​​What is holding me back is the software update part ... Im trying to track info about that, this might be critical part, Piwis can read write memory, it can process update as well as writing custom values.
So without solid information I can't proceed
Old Feb 23, 2018 | 04:54 PM
  #386
deilenberger
Perhaps contact the chap who sells the parts - it seems he's responsive. And maybe your local dealer's service department might be of help?
Old Feb 25, 2018 | 09:41 AM
  #387
radctt1's Avatar
radctt1
Default Potentially add 2016 turbo S
Recently purchased a 2016 cayenne turbo S. Taking it to dealership after experiencing exact descriptions of previous threads regarding lurch/missing shift thru especially 2-4 gears. Approximately 30 k miles on and still under warranty. Will update but my 2012 turbo did not have this sane ride issue. SA during phone conversation already mentioned transfer case so sounds like they have dealt with before. I will update once confirmed at dealership.
Old Feb 26, 2018 | 10:57 AM
  #388
pt911's Avatar
pt911
Wow, this is a long thread...amazing that Porsche is not addressing this issue more seriously. Wife's 2014 CS had transfer case replaced at 25k miles, now at 51k I drove it yesterday and symptoms are back again..
Old Feb 26, 2018 | 11:46 PM
  #389
e30rapidic's Avatar
e30rapidic
Also adding this here.
Did a fluid change after 3,000 miles and roughly 4 months. You can see how black the fluid was and the surprise I found stuck in the drain plug hole. I believe its part of a friction disk.
shifts smoother but still has some funky tendencies.
Old Feb 27, 2018 | 02:07 PM
  #390
CarGuyNVA's Avatar
CarGuyNVA
Default Another transfer case theory
Yesterday I was at one of two P dealers local to me that I do business with. While checking out some new rides, my salesman introduced me to one of their more senior technicians that happened to be in the sales area at the time.
In chatting with him about a number of things, we got on the subject of the 958 transfer cases. He mentioned the latest revision of the case (which we've discussed in this thread) and the associated new hardware like the vent kit, etc.
According to him, the issue has always been a contamination of the fluid. The total amount of fluid the TC holds is very little actually (1 liter or so?), so any small amount of contamination can have significant impact, and that impact specifically degrades the friction modifiers in the fluid which is at the root of the problem. In some cases a fluid change corrects the issue (which we've seen evidence of), and then in other instances the damage caused by the fluid contamination is more severe and thus permanent, requiring a TC replacement. He mentioned that the vent kit helps reduce fluid contamination, but it is recommended now that the fluid in those transfer cases (even the new design) be replaced every 20k miles.
Just passing on this information.
Cheers all.
