958.2 TPMS
#61
Searching TPMS threads I came across this one. I've got a busted off valve stem and having difficulty getting a tire shop to replace the stem without the sensor. Guy showed me what they wanted to use
for $99 plus mount/balance and it's a non removable stem to the sensor. I can get the mobile tire guys to come and they claim they can fix it for $50 flat but I have no idea what they'll actually come up with when the tech gets there. Porsche charges what, $25 for the stem alone. I'm not sure what to do unless I schedule the mobile and see what comes of it.
Porsche Tire Pressure Monitoring System (TPMS) Sensor Service Kit - Huf RDV006
![](https://cimg9.ibsrv.net/gimg/rennlist.com-vbulletin/920x2000/f9fd3e05_a2ee_4e18_9fab_6089b4a11754_ca0c514289a7fb7c63c6c614b51bd14579c6481a.png)
![](https://cimg8.ibsrv.net/gimg/rennlist.com-vbulletin/1500x2000/d2a317a9_d4e0_40ef_aab4_b6c2758b0878_46ef56f84cc12ce1abc3a34da4a44dbbe14d6ccc.jpeg)
3 lb.ft , torque it in one shot , no re-torque
#62
TY this looks exactly right. It's been a while already so time has been kind. I sort of fashioned a sleeve from a plastic cap that ha allowed me to air up a few times but this is ridiculous.
Guess I'll get the part and by force of will get some tire guy to use it.
#63
And then you know you've got one fresh battery. If the set is a few years old, you'll be replacing them sometime soon anyway...
#64
Piggybacking onto this thread with a semi-tangent:
I set up a winter set last month. Brand new TPMS, all good, worked great. Last week I had a tire swap done (same wheels same new TPMS). After they did that, the TPMS calibrated and the car learned them correctly - but after ~10 minutes of driving it reverted back to the "new tires? adjust settings" screen. Since then it won't seem to learn them, at least not in the ~30 minute drives I've done.
Any ideas for what could be happening? Why it would learn them but then forget them, and not re-register them? Is there a way to do a "hard reset" on the TPMS system to force a re-learn?
#65
You can get the sensor service done at most shops. A friend of mine has a garage and he works on mostly domestic stuff. His machine can copy the frequency and parameters of your existing sensors wirelessly and then program them into his universal ones. He has done them on a few of my cars including my 2017 Cayenne and they work perfect. He charges me $60 a wheel can’t go wrong with that.
ekranoplan (05-04-2023)
#66
Good points. I know little about these things. Just that the one they showed me looked pretty cheap and is definitely non repairable.
The fact that these stems are prone to corroding right off the wheel I found profoundly disturbing.
Thanks for the input.
#67
Sullivan Tire just spent an hour trying to wake up the sensors I got from TPMS.com
Huf Intellisens TPMS Sensor Set 9A790727502 433MHz
No joy. So I'm going back for a second visit in 10 days. They will pull the Huf sensors and install ones they source.
<sigh>
Or I could just put some black electrical tape on the instrument cluster where the error shows up.
<sigh>
#68
<sigh>
<sigh>
#69
#70
My pleasure, hope it will be resolved soon. best of luck
#71
<sigh>
<sigh>
So...I tried the electrical tape and it fell off.
Sullivan Tire swapped out the sensors for some they supplied, woke them up, and gave me back my car with a working TPMS system.
On top of that they discounted the sensors *and* didn't charge me for the tire unmount/remount. I figured the whole thing was going to cost $400+. They charged me $240.
Thank you Sullivan Tire!
End of story.
#72
End of story.
End of story.
#73
Barry was a good guy. Years ago he personally ground down some wheel bolts for me that were too long, and the shop was otherwise quite busy...
#74
#75
@marinerbc do you still have those tpms available? I have a 2013 CD and bought some summer tires but since they came from a 2018 model, the tpms installed on the wheels wont read on the dash.
yes I still do , pm me your shipping address and it’s yours if you want to.
