2011 Cayenne daytime running lights
Hi all.
I took my 2011 Cayenne to my OPC yesterday as i'm convinced that the daytime running lights are faulty. May be that i'm going mad but when I see other Cayenne's in daylight, you can clearly see the running lights are on. With mine in daylight it's very hard to tell if they are on. I seem to remember pulling up behind cars and seeing the lights in the reflection. Can't see them now. If you look really closely, it looks like there's a little bit of light at the ends, but that's it.
They are turned on via the computer, everything is as they should be. The dealer is saying that they are fine. But it's so hard to tell if they are on, kind of makes the fact that they are "Daytime running lights" pointless.
Any thoughts appreciated.
Just to add. The OPC have just sent me their photos. 2 different cars in the workshop and you can clearly see they are on. The 3rd photo shows the 2 cars outside with the lights on, which you can't tell. I this how they are supposed to be?????
Which model do you have? That's a TT/GTS bumper, but the headlights are wrong. Those models should have their DRLs in a ring around their low beam projectors. Is it different in your part of the world?
For what its worth, I did the TT bumper swap on my diesel and set up the signal bars to work as DRLs and they are very dim compared to what my factory DRLs were. But I assume that this is due to them just being parking lights. I don't use them anyway though as I'm against the idea (see too many people driving around at night with just the DRLs on thinking their lights are on).
Hi
It's a diesel with the Techart turbo front. I always preferred the look of the turbo but couldn't justify the fuel in the UK so just wen't for the turbo look.
The DRL's are in the same place as every other 2011 model Cayenne I have seen. You just can't see them in the daylight! Like I said, defeats the object of daytime running lights.
What I'm telling you though is that those lights do not have a DRL function in them. It's a trick of the wiring to make the parking lights (which are dimmer) act like the DRLs.
If you look closely at the light bars you have now and what is in a normal base/diesel/S/Hybrid (diesel S too?) bumper you will see that they are different. Your old lights had a second row of LEDs which are the DRLs.
You pictures looks pretty much spot on with the output of mine since I did the bumper swap. You can see a pic of mine after I did the swap in post 11 of that thread. Also if you follow the schematic link in the first post, that thread also shows some post-swap hacked DRLs and there were a few comments (if I recall correctly) about them being less light than the original.
Based on my experience and the pics that you are showing, yours are acting normally.
Hi
If you want the Turbo look, then you need the daytime running lamps which are in the headlight, not the strip.
Take a look at the model comparison.
The Turbo, Turbo S and GTS have the daytime running light in the headlamp.
That is different than the standard, S and diesel versions.
Because of that some good people figured out how to make an adaptation to the wiring harness to make the parking lights respond to the DRL settings (though they are dimmer as discussed in this thread).
Besides, it's the grill that is the appealing and recognizable part of the equation. Personally I think the DRLs in the headlights make them look bulky and aren't to my taste.
While i agree the bumper on the GTS or Turbo is super pleasing to the eye, i'm a huge fan of the quad led's in the headlamp.
Bulky did not even cross my mind when comparing the two styles. Regardless, quad DRL LEDs are quite rare in my area.
Hyundai's and every other car made today have LED daytime running strips. It's not cool anymore imo.
The rare times i see quad LEDs in a passing car, it turns out to be a Turbo 911, Turbo Panamera and Cayenne GTS/Turbo's.
Ya, i'm a fan.
Ya, i'm a fan.
Dear friends, well I have the same problem, my car is a porsche cayenne 958 diesel version and few days ago I changed the original diesel bumper for the turbo version,
and the day time ligths not work, do you know What can I do to make the daytime lights work again? or maybe how can I do to swap or set up the signal bars to work as DRLs
Thank you so much for your help, I apreciatte this!!
