CA smog failed as "tamper" due to incorrect emissions sticker for CTT
Hey folks, so this is a weird one. I finally found time to get the out-of-state '14 Cayenne Turbo I purchased two months back in for California VIN verification and smog. The smog tech said the car passed the test, but they have to fail it as "tampered" because while the car is clearly a Turbo in every way, the abbreviations on the emissions sticker do not include the code for turbocharged (I believe the TWC/HO2S/SIDI codes should also have 2TC). Since those codes aren't there, they have to fail the test since the car does in fact have turbos. They'd never seen this problem before. They called the dealership, who stated as replacement sticker is backordered for a long time. They suggested I call the smog referred and they will fix this for me, but has anyone ever heard of this?
Edit: just found this image from a 2013 CTT that was for sale as a dealership, and it appears to have the same codes. Now I'm wondering if the smog techs are missing something here.
Sounds like smog techs who think they are smarter than they really are.
The following 2 users liked this post by RAudi Driver:
Needsdecaf (05-04-2023),
Toreador (05-03-2023)
Now go back and get your cash back from those numbskulls.
This is some seriously stupid BS.
Meanwhile, here in Tejas, Diesels don't require an emissions inspection, just safety. So I can roll up with a straight pipe right off the header and pass.
Yeah, pretty dumb, although it is kind of odd that Porsche opted not to list turbos in the emission label (yes, it's clearly in the name, but it's also in the name for Taycans now and people are dumb).
I'm all for lowering emissions, but yeah, the whole system is pretty backwards. What they should be doing is sniff testing, and if emissions are fine, not do any visual inspection. Who cares if you have bigger turbos, intakes, and what not, as long as emissions are passable.
That's an interesting one. Inspectors do have to consult that label to see what items they have to check for. And extra stuff on the car that is not on the label might indicate an engine change so that is a justified fail. But they could have gone the extra step and checked thier emissions book and I bet TC is listed in there for this car. Maybe worth it just to remove the label entirely so they are forced to check the emissions book. Because the rule states this:
Underhood Emission Control Label: Each vehicle’s underhood emission control label serves as the primary source for emissions control requirements and to indicate the vehicle’s certification type (California and Federal). It is important to review emission control components on this label, since emission control system technology changes and varies between vehicle manufacturers. A missing or illegible emission control label does not constitute an inspection failure. In cases where the emission control label is missing or illegible, the inspector may proceed with the inspection provided that the required emission controls can be determined using other sources as described in section 1.3.1.
1.3.1 Visual Inspection Procedures Vehicle Emission Control Requirements: Inspectors must use all available information necessary to determine the vehicle’s emission control requirements, including but not limited to:
• the underhood emission control label (see section 1.3.2);
• a current emission control application guide;
• emission control repair manuals;
• emission component location guides;
• manufacturer emission control recalls;
• vacuum hose routing diagrams;
• California Air Resources Board (CARB) aftermarket parts listings;
• the aftermarket part label (see section 1.3.2);
• and any reliable vehicle manufacturer sources
Thanks, yeah, the first smog techs were basically just lazy/uninformed. The second place I took it got out the manual, saw it was a 4.8t, and moved on. They said the first place wasn't doing their job properly. *eye roll*
