Brake pedal does not return
#31
In my case the problem happened after fluid change, my car is Cayenne S V8 2012.
But the failure behavior is a little different, it never happened when the car was running or driving. My problem happens after park the car and leave it for a few hours and always in a very hot situations.
I'm trying to understand the problem. I'm going to do some tests and replace the fluid again, using Motul RBF 700. As soon as I have an update I'll post the results to help other owners with this same problem.
#33
#34
It picks up moisture too quickly which in turn lowers its spec/performance, which is fine for a car that gets its brakes frequently bled like a track car, but not a favorable attribute for a Cayenne getting its fluid changed every 2 years.
#35
My first really hot day since owning the car and my break pedal is doing the same. Absolutely fine in normal weather and over a 4 hour drive. It is also making my auto box gear changes very odd
