LED Headlight Conversion Kit
#61
peterb1986 (06-28-2023)
#63
#64
Us source
Just received and installed upgraded led headlights from “Seems Legit Garage” in Michigan. Set was $1,400 but, it took 20 minutes they have a light tint color (probably just back inside) and are literally plug and light. Our headlights 958.1 have a single plug and held in place with only one rotating clamp down. Super easy and love the results. Now have to think about the tail lights
Visualistics (07-01-2023)
#65
#66
I am sure they are Chinese made. They come with a 90 day warranty for whatever that is worth. But factory LED's from Suncoast are like $3500. You could go through 2 sets of these and still be ahead apparently without the programming headaches. They claim to support PDLS.
#67
I think it's same ****. There are only a couple of major manufacturers out there. The rest are resellers. I used to be in the HID business and worked directly with the manufacturer. Then learned about the resellers, who's major downfall was warranty.
I've been thinking about those headlights myself, just keep forgetting after a while.
As far as ordering to the US from Ali.... shouldn't be an issue, I've ordered lots of random things mainly due to curiosity. The only stuff that gets held up are things with batteries.
Here are a few links. I believe AKD is the main brand here. The price difference seems to be based on one headlight or both. Average price $600
US $1,181.50 15%OFF | Applicable to 2011-2017 Porsche Cayenne LED headlights and headlight assembly installation
https://a.aliexpress.com/_mOiNnF2
US $645.67 44%OFF | Headlight Assembly LED For Porsche Cayenne Macan 2011-2020 Car Day Running Lights Fog DRL Lamps Accessory Brake Stop Turn Signal
https://a.aliexpress.com/_mLL1ZKu
The cheaper one is a LEFT headlight.
#68
downtroddengoat (07-08-2023)
#69
I'm more interested in the interplay between my cornering lights and manual highbeams i suppose. My neighbor with the dark blue metallic 958.2 who appears to be melting into their seat still has the better ride, but it'd be nice to work towards catching up when possible.
#72
Initial check
Everything works as it should, I bought through SLG because they are responsive, friendly and nearby in Michigan. I prefer for $100 more to buy from someone who answers emails and calls and takes less than a month or more for delivery.
they also have matching set of LED tail lights that will be next. Put a layer of vivid tint on back and like the subdued look. Sun coast or others at $600 have the outside look but a sequential LED turn signals just modernize the back side. Chinese or otherwise are all about $1,000 when done so why not these guys for about same price and faster delivery et al
I have no relationship with SLG ! Just looked all over before selecting them and passing this along
#73
AliExpress is... I hope it all works out. Sometimes yes sometimes no. I may have clued the seller referenced above that there are inquiring minds at Rennlist (no links, etc not a subsidiary or anything, just that maybe it helps?)
