Oil Leak
Oil Leak
I moved the Cayenne to change the oil and there were significant oil drips on the garage floor. Never had that happen in the past. This is a 2016 Cayenne base with about 85k miles. The oil looks to be coming from around the oil filter housing. The housing seemed tight when I removed it. Did not know what else to do, so replaced the O-ring and filter and the small center drain plug, and put it back in. I had about 6k or 7k miles on the oil before the change.
The last trip I took was taking the GT4 to a track event, about 5 hours away. I have a small, lightweight aluminum trailer, so the total load was not anywhere near the towing capacity limit. Most of my drive was on I-95, and I was going pretty fast (with traffic), cruising at or above 85 mph. The oil is Liqui Moly and meets Porsche specs.
Anyone have any thoughts?
When you went to retighten the small center drain plug did it recess into the cap more than what's showing in this picture?
I've never seen. cap like this so had to look it up and it appears to be a Genuine cap but the pictures on the internet show that center plug super recessed.
I have changed the oil several times without replacing the drain plug and never had an issue until now.
I will drive it some and check it again. Now I am paranoid
Did you do your last oil change or did a shop do it?
Also that small filter cap drain plug also has a baby o ring on it. Did you see it when yo were working on it?
That gasket and housing is likely quite sensitive to torque. Did you use a torque wrench? It actually states the torque spec on the housing, which is probably a pretty good indication that proper torque is important. I believe it was 25lbs or 25nm, can't remember which.
Good questions!
I did the last change.
Did not use a torque wrench, but, but, but I have a decent manual calibration on that. Okay, no excuse, especially when it's actually not a huge PITA to use the torque wrench. When I check it, I'll get the torque wrench on it. I see the irony here...guy posts about oil filter housing leaking and doesn't bother to torque it! Argh!
The O-ring I removed was in the groove fine, at least when I got the housing out. I assume it was fine when installed.
Thanks for the feedback!
What about the o ring in the drain bolt that screws onto the filter cap?
aryork (10-17-2022)
Seeing the Audi in your screen name reminded me...I also changed the oil in our 2020 Q3 yesterday.
As an aside: this is the easiest vehicle for which to change oil I have ever owned. Filter is on top and easily accessible and changeable with ZERO oil spill. The drain plug is a quarter-turn type of plastic fitting with an O-ring.
Anyway, the drain fitting had some oil around it, which it had never had in the prior several changes I have done. It probably had a few drips every now and then, but I never got one in the garage. Also, I had never changed the drain plug even though I had a new one. Thus, I used the new drain plug this time and will be interested to see if it stays 100% sealed. Here is that fitting:
Ahh, so the baby oil filter cap bolt gets replaced during an ol change. I thought it stayed with the cap and only the o ring was replaced.
Porsche Engine Oil Change Kit (5W-30) - Liqui Moly/Mahle 92ABASEOILKT | FCP Euro
Yea, my filter cap doesn't have the drain plug and it's always a bit messy upon removal
Well, went back under there, one day later and, alas, there is some oil starting to come out. It was torqued pretty close. It calls for 25 Nm or about 19 ft lb. I had about 22 ft lb on it, so I loosened it and retorqued it. I ordered a new housing tonight. I should have done a detailed inspection of that housing when I had it out.
When I replace it, I will check the metal sealing surface to make sure it is clean and smooth.
Make sure that cap is OEM.
I would try this aluminum one from ECS, but not available any longer...
https://www.ecstuning.com/b-ecs-part.../001982ecs01a/
In looking at some other threads, several people mentioned they added an LN adapter that can use 'old-fashioned' can-style filters.
https://lnengineering.com/spin-on-oi...e-s-turbo.html
https://lnengineering.com/products/d...ange-kits.html
