PDCC hum / whine. Is there a fix?
#47
gawd I wish I knew this before paying a shop to “fix” this. Not fixed, just a few K bucks lighter. Then I put a few $2 plastic clips in place, fixed the bracket holding the PDCC expansion line, and it got better (not perfect, but better).
#49
scroll up to:
https://rennlist.com/forums/cayenne-...l#post18535091
basically, if you make sure you have all the rubber grommets holding the bracket for the pdcc expansion loop, and all the plastic clips routing the lines around the a/c compressor etc., the hum should get a lot better.
