Sponsored By:
Sponsored By:
Is it impossible to DIY rear pads and rotors on a 958.2 S without a scanner?
Old 03-06-2022, 11:23 AM
SoundsoftheSuburbs
SoundsoftheSuburbs's Avatar
Question Is it impossible to DIY rear pads and rotors on a 958.2 S without a scanner?
Is it impossible to DIY rear pads and rotors on a 958.2 S without a scanner? We have DIY'd pads and rotors on the 2019 Audi Q8 and 2015 Mercedes-Benz GL63 AMG without issue, but the research that I have done says that there will be an issue related to the parking brake calibration if doing the rears on a Cayenne S 958.2 without a scanner.
Old 03-06-2022, 11:26 AM
PFDGSB
PFDGSB's Avatar
I haven't done it yet, so I can't comment directly. However, you may consider investing in some type of scanner. IMHO, you'll need it at some point. I use a Foxwell NT530. There are many options.
Old 03-06-2022, 11:42 AM
Rocknroad
Rocknroad's Avatar
It's my understanding that, yes, you need a device to open the electronic brakes to work on your rear brakes. I am going to do it soon, as I purchased the iCarSoft POR V2.O for my 2013 CS. It does have the ability to override the e-brake and works perfectly.
You can find them on eBay, for $125-$150.
Old 03-06-2022, 01:19 PM
Umber
Umber's Avatar
You can do it without scan tool, if the inner surface of the brake disc doesn't have a lip preventing it sliding over the parking break shoes... I would however recommend getting a scantool to make sure you can complete the brake job in all conditions
Old 03-06-2022, 05:05 PM
MBDiagMan
MBDiagMan's Avatar
Well I replaced the rear pads a couple of months ago with no issues at all. I didn’t know that there would be any kind of a problem.
Igmorance is bliss I suppose.
SoundsoftheSuburbs (03-31-2022)
Old 03-06-2022, 05:51 PM
KBell
KBell's Avatar
Umber is correct. I can be done without scan tool.
Love MBDiagMan's comment.
Old 03-06-2022, 07:57 PM
hotrod2448
hotrod2448's Avatar
I did rear pads and rotors on my CD without needing a scan tool. It's a 958.1 but, it has an electric parking brake. I be surprised if there is a significant difference.
Old 03-06-2022, 10:59 PM
Whitegalaxie
Whitegalaxie's Avatar
Really you might only need the scan tool to change the rotors maybe. For brake pads only no tool is needed. Just squeeze in the pistons with a piston/pad spreader. Only reason you need the tool is to adjust and calibrate the park brake to specs.
Old 03-11-2022, 04:57 AM
porschedad_73
porschedad_73's Avatar
Just did the rotor and pads couple months ago. Did read about the possibility of needing the scanner to reset the e-brakes but only if they are really worn. I went ahead without doing the scan and everything worked out fine.
Old 03-11-2022, 11:24 PM
Kris Murphy
Kris Murphy's Avatar
I've done mine without the scan. I think it depends on how much you use the parking brake. I never use mine, so it is not worn down, so the rotor just slid of and back on.
Quick Reply: Is it impossible to DIY rear pads and rotors on a 958.2 S without a scanner?
