Help with Auto Headlight and Trunk liftgate shocks
Hi guys. Couple of quick questions on my 13 CS please.
1. Auto Headlight-light came on during noon time, bright daylight. Happened twice in a month. Hasn't happened again. Light also would not come on one time when it got dark. I had to manually turn it on. Do you think the sensor is going bad? I had to have my car jump started recently due to not driving it in a month. This didn't happen prior to jump start. Battery is less an 1 year old.
2. My trunk lift gate opens 3/4 of the way. I suppose I should consider a replacement. OEM's are very pricy. Any aftermarket suggestions? Is it hard to replace? Do you have to un do the trim pieces? It looks like the screws are right there but I saw on the older models where the guys took out the trim pieces.
check your manual, but I think you hold the close button til it beeps, then move it open to the height you want.
There’s a DIY for the tailgate. I used Porsche struts but some folks later found cheaper aftermarket ones.
I was looking at this one but couldn't find any information on it so I decided to purchase OEM from Gaudin. Blaine, did you have to take the molding trims out?
https://www.ebay.com/itm/28402911483...01e3%7Ciid%3A1
That's the one I purchased on EBay from the same seller. If I recall you need to remove the interior panel on the liftgate, a couple screws hold in the lights, a couple screws in the what looks like a tool compartment (the screws are driven through the Velcro), then I believe the entire panel pops out. Really simple...
