Sponsored By:
Sponsored By:
PCCB issue
Old Aug 18, 2020 | 11:54 AM
Radi's Avatar
Radi
Default PCCB issue
Hello everyone.
My 2014 CTT has a strange issue whit the brakes. A have a OEM PCCB. The problem is when hit the brakes at speed about 70 miles or higher a have a vibration on the steering wheel. I now that happen on steel disk breaks. The question is can it happen on carbon ceramic disk. Is there a some kind a maintenance for those disks.
Old Aug 18, 2020 | 03:31 PM
squid42's Avatar
squid42
This is unlikely to be caused by the brakes.
Old Aug 18, 2020 | 04:26 PM
KBell's Avatar
KBell
Front wheels unbalanced?
Wheel weight fall off?
Road debris like tar, small rocks, stuck on wheel barrel?
Look at all your wheels.
Make sure the barrel is clean, free of ANY debris.
Have the front wheels rebalanced.
Keep us up to date.
Old Aug 18, 2020 | 05:06 PM
Radi's Avatar
Radi
A have 21” turbo wheels with new Michelin PS4, and 21” turbo ll with Michelin for winter. The problem is not whit wheel. It’s a disk issue but how it’s possible?
Old Aug 18, 2020 | 05:17 PM
Spyerx's Avatar
Spyerx
if the issue is under braking and not when driving (ie no vibration) it's less likely a tire balance issue, I've not heard of issues getting deposits like iron rotors.
What I would check, in this order:
wheel bearings
brake pads don't have deposits or issues
tie rods
shocks
other suspension components
Old Aug 18, 2020 | 06:00 PM
KBell's Avatar
KBell
I understand.
However, My above recommendations are simple and quick things that can be done to rule out bigger items.
Old Aug 18, 2020 | 09:42 PM
RAudi Driver's Avatar
RAudi Driver
Loosen and retorque your wheel bolts.
Check tire wear
Inspect discs for missing hardware.
Old Aug 19, 2020 | 10:11 AM
TRD_Power's Avatar
TRD_Power
Though it may not sound like a tire issue since it happens under braking, I had a practically identical issue with my Lexus a while back (obviously not equipped with PCCB), and it turned out it was just a poor balancing job done by Discount Tire. Took it back to them twice, but they still couldn't get it corrected, so I ended up taking it to a specialist in WA, when I still lived there, called Tru-Line. Had to pay $125, but it was well worth the lack of headaches from that point on. Like your car, it only happened under braking at around 65-75 MPH; didn't feel a thing when I wasn't braking while driving at those speeds.
Old Aug 19, 2020 | 11:23 AM
Radi's Avatar
Radi
Thanks guys
I will check tires for issue. Tomorrow will post a video. I spoke with Porsche dealer and they told me that no way pccdisk has a issue.
l check the suspension......
Old Aug 27, 2020 | 10:00 AM
Radi's Avatar
Radi
PCCB vibration
File Type: mov
Old Feb 25, 2026 | 08:38 PM
GRIEHL's Avatar
GRIEHL
did you ever fix this>
Old Feb 26, 2026 | 02:34 AM
Radi's Avatar
Radi
No, the problem is in the front discs a thing
