PCM play USB?
Received 1,150 Likes
I use the storage format of:
Artist
-- Album
>>>> Track 1
>>>> Track 2
etc..
BTW- more than 5,000 tracks takes a bit of time to index, and for some reason it doesn't store the index it creates it every time you select the USB port.
Also know there are track limits on the PCM. There was a good thread about this on another forum: https://www.macanforum.com/forum/ele...rd-limits.html
So while you can have very large removable media, the PCM itself will only recognize up to 10k tracks on it.
I had issues with my Windows PC formatting some USB sticks of various sizes, and I was using FAT32 and ExFAT (required for sticks over ~4GB size). If you start the car, let everything in the PCM get settled in (Jukebox, XM, bluetooth, etc..) THEN, plug in the USB stick and watch the bottom of the display - is there an error? If it can't read the USB stick, you won't get it as an option.
I ended up formatting the stick on a Mac, and it's worked ever since. It's an option to try.
That said, I know we can "turn off" some inputs like AUX and AUX BT.. can that be done with USB? I don't think so, but worth skimming the manual.
The tricky part with USB sticks is not knowing how they've been set up previously, and untangling that. Some may have come already setup for some other purpose. You may have to eliminate all of that in order to start fresh for use in the PCM (or anywhere else for that matter).
Bare-bones, FAT or FAT32 with a single partition taking up the whole stick is your best starting point. When setting it up for partitions it's best to use MBR and not GPT.
There's a very good free tool called 'Rufus' that's great for formatting drives. https://rufus.ie/
Just be aware that when using tools to format drives that you're formatting the CORRECT ONE. Don't format your data or operating systems drives out from under you!
Thanks - that was going to be my next step - format with using FAT32 or NTFS depending on what it was (wifey likes the music and took the flash drive, so I'm gonna try again on a different drive).
Appreciate the heads up on formatting the right drive - I build my own gaming computers and am a software developer, won't be an issue lol.
To save you exhaustive efforts (I know, I'm also an IT guy) there's no reasonable way to get more than 10k tracks on a drive.
You can jump through some silly hoops to put multiple partitions on a single drive and the PCM will see them, but doing so will keep a windows PC from seeing them, so you'd have to be using a linux/unix box to talk to set it up, and remember it's set up that way in the future.... etc.
The end result is while you can buy incredibly large storage drives, the PCM won't ever be able to use them to browse "all" your music. If you have more than the track limits the PCM imposes it's just wasted space. The only upside to that is you can use higher quality tracks, but then you're down a whole other rabbit hole obsessing over media quality.
I've long been a fan of J.River's "Media Center" program for managing media. And apparently their upcoming release (version 25) is going to have some better renaming options for doing device sync transfers. It's a swiss-army-knife of a program. Tons of features, but you REALLY have to understand what you're trying to do. It's not as simple as I'd like, but managing tons of tracks in lots of different formats isn't easy. It's worth the commercial price if you've got years worth of media that needs re-organizing.
