CarPlay Retrofit in PCM 3.1 Cayenne 2013 ( With Pictures )
Willy07 (12-06-2021)
#1232
Yes, the 11/24 update will only have ISPBOOT.BIN file and the OSU_Settings folder with 3 subfolders.
I also included the new icons that @konkab used in the update to the 0805 update, into this version of the 1124 update, if you are interested in a better looking Porsche icon - https://www.dropbox.com/s/pfhhk2o7xw...2021-11-24.zip
BW369 (12-06-2021)
#1235
Joyeauto firmware update stuck on "Burn success, welcome!" screen
Hi Konkab! I upgraded by newly installed Joyeauto unit following your instructions. It's stuck on this screen; I restarted the car several times, also had it turned off for a long while. Cannot access the Joyeauto menu at all, when I press "Navi", that's all I see. Any help or guidance would be much appreciated!
Firmware upgrade - success screen - then nothing...
#1236
#1238
Hi - thanks a lot - I unplugged the cable from the box and the Joyeauto unit restarted. I think the cable was plugged to an “always on” slot in the fuse box, and that’s why the unit did not restart even with ignition off overnight.
#1239
Anyone succeeded to get better bluetooth quality? As I understand the main reason is that our chinese device supports only the weakest bluetooth audio codec: 'SBC'. Interesting if it is hardware or software limitation?
#1240
Hey @konkab , have you taken a look at the guts of the MCU firmware update, to see if there is a way to fix that steering wheel return button issue?
#1241
Hi folks,
Just installed the Joyeauto unit to the PCM3.1. Have an issue connecting android phone to wireless Android Auto. The phone is running Android 11 and the "Wireless Android Auto" option is enabled. Following
instruction but there is no WiFi from the joyeauto unit visible to the phone. The phone seems is getting a command via Bluetooth to connect to a wifi (it auto enables WiFi if disabled) but there is no WiFi network (nothing similar to what shown in video) it can connects to. As a result an error appeard (WiFi connection tied out) on the HU screen and that's it. It works perfect via USB cable connection and I have no apple phone to check if the carplay has similar issue. Is there anyone faced similar problem ? Any advice ?
#1242
Anyone in the SF Bay Area have experience doing this install? Happy to sit by to do it together over beer or something.
also, reading the thread seems like some folks have problem with joyeauto and prefer the NM from UK. Can they even ship to US? First half of the thread says no.
#1243
The NM lot can be shipped to the US, I purchased one myself. If it were me buying another one (I actually will be buying one for my Macan) I would avoid the Joyeauto and buy the NM lot. If you run into any issues, the support you receive from NM will sort you out quickly.
#1245
Dammit. When are you heading down to Socal @UH2 ?
