CarPlay Retrofit in PCM 3.1 Cayenne 2013 ( With Pictures )
#1097
I'm a Mac user too. Format a USB drive to Fat32, then copy the contents of BSJ_2021-09-02 folder (make sure no other files are inside the USB drive). The only items you should see are ISPBOOOT.BIN and the folder titled "OSU_Settings". Then insert the USB drive to the USB female cable provided with the iSudar module. You go to the same place where you showed me the photo of the version and you should see an opinion to update. Click on Update, and you should be on your way. Hope this helps.
#1098
BW369 (10-05-2021)
#1099
Sooo....thinking seriously about this now. I've read the first couple and last couple of pages, but not going to go through the 70-odd pages in between. lol. Is everything still similar to the first few posts with the exception of updated firmware? Everyone still recommend this product? Would love to get CarPlay working in our 958.
Thanks.
Thanks.
#1100
Thanks.
Thanks.
#1102
The kit from NM Automotive is the best one out there. Was a trouble free install. I have had no issues as compared to the other venodrs products. my 2¢
HMonk (01-14-2024)
#1106
#1107
I can say, after testing both Isudar/Ebilaen and the Joye modules, that from those two, the Isudar/Ebilaen is superior. I have described in detail the reasons in previous posts. But for me, the speed alone is a significant factor. With the Joye module I needed to perform a lengthy procedure just to connect the way I wanted (which was not using the AUX). Isudar is almost instantaneous, with 5GHz Wireless connection instead of the 2.5GHz from Joye
The quality of sound through AUX is much refined than Joye, with a much better DSP.
Package is more compact without the need of an external box.
True, the Isudar/Ebilaen have some very minor quirks that we are working with them to resolve, but they are minor. I’m not going back.
Now, I can’t say anything about the NM Automotive module, because I haven’t tested it. Perhaps you are right, but unless you test others, there is no way to know for sure. However, from the outside, it seems that the NM Automotive module plays in the same space as the Joye Module? Board looks almost the same as Joye, with the external module…. Not many specs out there.
When I had the Joye, I was happy with it too. Decided to give Isudar/Ebilaen a try… and now I’m even happier.
#1108
question for those that got Isudar
1. I didn't have the optical (blue) cable to remove from the main harness and add to the new harness, what is this used for?
2. I didn't plug in the supplied mic yet everything works except Siri anyone run into this?
3. where are the updates posted or does it require a subscription?
thanks
thanks
#1109
thanks
thanks
2. In the iSudar module settings check whether you have enabled the original microphone
3. No subscription required, but the recent update was shared in this forum by @konkab
#1110
I just uninstalled my setup - available to anyone if interested - make me a reasonable offer $100 w FREE SHIPPING!
https://www.aliexpress.com/item/Appl...820507140.html
phil.
phil.
