2013 Cayenne 3 l Diesel RMS replacement
We need some advise on the procedure in replacing the Rear Main Seal on this Vehicle.
It looks as if you have to drop the engine,Transmission and front suspension in order to get to the seal?
Or can you do it from below by only dropping the Gearbox and Transfer Case?
Regards
Schalk
Regards
Schalk
I looked at AllData, you have to remove the transmission. There were some 2013/2014 cars that had improperly sealed timing chain covers ( at rear of engine ) from the factory that might be the cause. Do you have any warranty left?
It really needs some more investigation.
Regards
Do you have oil on bell housing? Ivesrtigate the top of the motor. Back side. Search for threads on timing cam seals. Likely that. Known issue. And it’s a huge job to fix it.
Would this not be covered under the diesel warranty?
