How to tell if the car is PDLS equipped ?
I wonder if I have the PDLS option installed. My car is Cayenne 958.1 (2010-2014) with bi-xenon (HID) lights.
The easiest way is to plug your vin here and see
https://www.vindecoderz.com/
Alternately, you can tell if you see the a side light when you turn the wheel with the vehicle moving slowly. It is a very subtle system though.
Received 1,150 Likes
Or, watch when you turn the key on (in the dark, of course). Do the lights go through some funky chicken dancing? Up, down, left, right then back to normal? If so, you have PDLS. If not, no.
But don't bi-Xenons mean PDLS, by default?
![Thumbs up](https://rennlist.com/forums/images/icons/icon14.gif)
I have the bi xenons, which are different from the Porsche Dynamic Lighting System. When I turn my wheel left and or right, there is an additional light that illuminates to light up the direction I'm headed. The PDLS will actually turn a single headlight (right turn, then right headlight), in the direction you are headed. It's a great thing that I have on the other cars but my cayenne didn't come with them.
Following a friend the other night......came up behind him and my PDLS adjusted the lights downward. He thought I has a loose lens. Then I showed him how it worked around a corner. Great lighting system much better than a similar one I had on a Grand Cherokee.
I have also read, that you can check that in the vehicle menu settings. If your car has the L/R driving option under Vehicle > Settings > Light & Visibility > Exterior Lights then it means you have PDLS.
![](http://www.porscheownersmanuals.com/manual/2015-cayenne/images/2015_cayenne_pg130_cht1.jpg)
Sorry if OT... My new-to-me Cayenne diesel happened to come with Premium Pkg Plus. I’ve seen that the included LED headlights, which come with the PP+, can be as much as $3k more than the bi-xenons. Does the LED package w/ PDLS provide any additional features over the xenons w/PDLS? Has anyone done a comparison between LED and the xenons?
I also noticed with my LED option that I have a feature called Headlight (or high-beam?) Assistant. This feature automatically dims the high-beam when it senses oncoming headlights or if you are following a another car. Is this a feature of the PDLS?
And as for swiveling, both lights swivel, not just one, when turning.
Thanks for this useful tip. Indeed, the lights on my car go up, down and then sideways. It means the car is equipped with PDLS,
Here is a short vid I took of the PDLS headlights initializing process:
Please note that this is an EU car, with EU light pattern (right side rising up on each headllight) which is different to US light pattern (flat).
