PDCC Whine is finally acknowledged by dealer
Good to know that some noise is normal. I'll bring up the whine again the next time I stop at the dealer. It very possibly could be louder than the last time. ![Big Grin](https://rennlist.com/forums/images/smilies/biggrin.gif)
I have new reservoirs on the way. I think I'll wait to replace them until after the pump is replaced. Assuming here that the fluid in both systems will be flushed with the pump R&R.
Thanks!
Thanks!
I would change the reserviors before the car went in for work.
If you get the car fixed, then go home and change out your reservoirs, then the car has an issue, the dealer may not fix the car. They might blame the problem on the work you did to your car.
I replaced both reservoirs and flushed the fluid on both sides, per the excellent procedure in the DIY section, about 3 months ago. Unfortunately, no change in the PS pump whine after the flush.
The DIY was excellent, thank you!
At this point I consider the whine an 'aesthetic' issue, the steering and PDDC work fine, but the whine just not in keeping with the character of the car.
The challenge of course is figuring out if spending $1,200 on a pump (plus at least that much in labor if I don't DIY) will actually address the whine long term...
It only gets worse to the point you're going to have to fix it. Since that's the case, why live with it any longer than necessary. I don't have the whine any longer. It's pretty silent.
And that pump is crammed in their. I thought mine was leaking and thought I was going to have to replace it. Luckily the leak was from a broken valve cover bolt. I was not looking forward to replacing the ps/pdcc pump.
at the dealer on my dime, getting inspected to see if they can do anything about it.
dying here for a resolution. Thanks!
My pump is so quiet, I can't even hear it at all. However, I am in a new Audi Etron Chronos and the wifey is driving the Cayenne now. ![hiha](https://rennlist.com/forums/graemlins/roflmao.gif)
All kidding aside, my pump is pretty quiet.
Mine originally wasn't making a whine noise, but the pump was vibrating badly. This was replaced with a reconditioned one. Works fine but there is now quite a loud whine / whirr. My garage (indy) also replaced some missing / damaged mountings when swapping the pump. I wonder if there are more missing, or if this whine is just the normal sound when it is mounted as intended. I don't mind the noise per-se, it is just hard to know if it indicates something is not quite right, such as insecure mounting which would eventually lead to damage.
Sorry, I lurk in the 957 forums…
this might help, the 957 parts are detailed in post 41in this thread:
https://rennlist.com/forums/cayenne-...l#post18593614
