Memory seats buttons not working
After replacing the battery (I guess) the memory buttons stopped working. nothing happens when 1 or 2 is pushed,. the Off does light up/turn off and beeps, fuses OK
I would appreciate any help.
thank you.
thank you.
We've had exact same problem for last 2+ years but haven't figured how to fix it
Yeah you basically need to reteach the end positions of your seat. Run it in every direction all the way until it stops, then try to go further. This will teach the motors where thr mechanical stops are and assuming there are no other issues the seat memory should start to function again.
I have to keep the memory button pressed in until the seat positions are reached. If I just briefly press the button, the motors just run for a very short time.
Is this normal, or should a quick button press get the seat to move into position?
Cheers,
Tore
Cheers,
Tore
Both for my 718. When first entering the vehicle (key not in the ignition/ignition not turned on) I only need to press once to get it adjusted to my seat memory. But once the key is in the ignition I need to keep on pressing the memory button until it reaches the right position.
Ah, thank you, I bet it is the same in my car. Safety feature I guess.
Cheers,
Tore
Cheers,
Tore
deilenberger (04-29-2021)
