Hello everyone,
Picked up a 2015 CS back in July. It has the pano roof without the factory roof rails. I'm trying to figure out whether there is a combination of crossbars/cargo box that, when installed, will still let me park in my garage. I can find cargo box specs but I can't find any info on the distance from the top-of-roof to the top-of-crossbar for the bars I'm considering. I'm zeroing in on the clean look of the Rhino Rack RS 2500 Aero bars as the bars do not overhang the end mounts. Whispbar makes a similar aero unit as well that is flush with the mounts. (With Thule you are forced to buy longer bars which extend past the mounts unless you have the factory roof rails). Does anyone have either the Rhino or Whispbar aero crossbars on a 958? If so would you be willing to measure from top-of-roof to top-of-bar? Ideally, this would be done on each bar at the midpoint (e.g. centerline of the vehicle). Or, if anyone knows where to find the specs on these bars, I would greatly appreciate it. I have made some inquiries to the manufacturers but have not yet received a response.
Thank you,
Kevin
Check the load rating of the bars/mounts you are looking at. When I looked back in 12 I found it was only about 100lbs compared to the factory system supporting 200. Depending on the box you are using, that can eat up a good chunk of the 100lb limit.
I have heard of some people successfully getting the factory rails installed by a dealer (one in Seattle is the case I know the most about), but more get "no" as their answer. You might look into that as an option too.
I am in the process of purchasing some factory roof crossbars and I will put my Yakima skybox 16 on it. Once I do that in the next few weeks I'll send a photo and measurements.
I heard back from Rhino. Their cross bars add 3.5" to the height of the vehicle. Thule makes a low profile box which will work work with these bars and leave me an inch clearance.
This will work for skis, boots and a few extras when the four of us head to the mtns.
I prefer the look of a naked roof so am only interested in this "temporary" solution rather than searching a dealer willing to install the factory rails. Load capacity is not an issue as I'm not looking to carry a lot of weight.
I am in the same boat, looking for an answer. Naked roof with Pano sunroof, no factory rails.
I was looking into Whispbars, but suddenly I thought whether it would be a problem with the frame. I am talking about the total weight clamps to the frame with a Roof top box.
Yeah, at the time of the purchase. I never thought snow sport is my thing until I got hooked 2 month later. FML.
We had Yakima racks on our previous SUV and put them on our CD 'Otis' They are not robust enough for what we do. Looking to replace our racks with Front Runner as these are well built and versatile with many options. https://www.frontrunneroutfitters.com/en/us/
We did look at Rhino, Gobi and other racks, Front Runner seems to be the best for us.
____________________________ https://rennlist.com/forums/porsche-...meet-otis.html
I have the Rhino setup and I use it on both my pano and standard roof Cayennes. I don't have it mounted right now, so I can't get you any measurements, but I posted some photos in a previous thread here:
I had a similar set of questions but went a grabbed the whispbars. Honestly they are great looking bars and I have them on a c-class as well. Whispbar was bought by Yakima so the prices during the rebranding make them a great deal. I snagged the last set on Amazon of the S28 bars on prime and picked up the K527 foot set for a total of about $305 shipped. Not bad for the bars with no overhang.
So- I have a panoroof- and no factory rails, so I plan to take them off most of the year and store them. The clearance from bar to roof is 5.7cm. I just measured it. I think the pano might clear but I'm not even going to try. With a roof box on- that drops down even maybe only 2cm of clearance so it would be impossible to open for sure. Depends on the box, but this was on a Thule box.Overall- is still buy these again considering the price. Fit perfect- and better looking than the dorky bars, or square ones for $400+.
As luck would have it the vendor I ordered my Rhino bars from didn't actually have them in stock and they wouldn't be able to ship in time for my upcoming trip so had to cancel. Couldn't find them anywhere else within my time constraints but was able to find a set of the Whispbars (with a large discount no less). Bars arrived yesterday and look like a great product. Was a bit concerned since the Whispbar website shows compatible with my CS but none of the various retailer websites do. (not even Yakima's website). Good to hear it does indeed fit and work well.
Should have the fit kit and cargo box early this week, then can get it mounted.
Km
