958 Service Campaigns and Recalls
Received 1,153 Likes
This thread will document the service campaigns Porsche has issued for various 958 models. It will also cover Workshop Bulletins and NHTSA and other recalls.
For the moment I'm going to make it a closed/sticky thread, and ask that anyone with info please PM me with that info. I'll put the info into a standardized format - hopefully making it easy to find and use.
Thanks to Chao for the idea!
porschepanamera1 (06-22-2024)
WC-22 and NHTSA Recall - VarioCam failures, V8 engines, 2011, 2012
WC-22 was an initial action on the part of Porsche to address failures of the fastening bolts on the VarioCam adjusters used on the V8 engines for Cayennes produced from late 2010 to early 2012. These were sold as 2011 and early 2012 models in the US. This campaign was for a very limited range of engines. WC = Workshop Campaign - something the dealer repair departments are supposed to perform when the vehicle is in for service.
Since the failures continued on vehicles not covered by WC-22, and it was found that recalls were issued for the same problem over a much wider range of VIN's in Japan and China, NHTSA in the US got involved. Porsche then issued Porsche Campaign AH08, which is a RECALL on a wide range of the engines used in the Cayenne and Panamera vehicles. This is an ongoing recall. It was announced early spring of 2017, and in late fall no parts availability has been announced. This recall effects approximately 18,000 vehicles in the US.
This also was followed up by a RECALL action in Canada, http://wwwapps.tc.gc.ca/Saf-Sec-Sur/...&pg=0&lang=eng - basically identical to the US announced recall. This recall effects approximately 1,800 vehicles.
Details on the failures, and a history of what happened can be found in the thread: https://rennlist.com/forums/cayenne-...cam-bolts.html here, and a more extensive one on 6speedonline.
Originally Posted by NHTSA
June 7, 2017 NHTSA CAMPAIGN NUMBER: 17V368000
Camshaft Controllers may Loosen and Fail
An engine stall can increase the risk of a crash.
NHTSA Campaign Number: 17V368000
Originally Posted by Transport Canada
Transport Canada Recall # 2017296
Recall Date: 2017/06/07
Notification Type: Safety Mfr
System: Engine
Manufacturer Recall Number: AH08
Units Affected: 1,823
Category: Car, SUV
Recall Details: On certain vehicles, the fasteners of the camshaft adjusters could fail due to an assembly problem. If this occurs, this could cause abnormal engine noises, vibrations, illumination of the check engine light and could cause the vehicle to stall, increasing the risk of a crash causing injury and/or damage to property. Correction: Dealers will replace the fastening screws of the camshaft adjusters and if necessary, replace the camshaft adjuster assemblies.
System: Engine
Category: Car, SUV
Excessive Oil Use, 2011-2013 Cayenne Turbos
The early 958 Cayenne turbo gained a reputation as an oil burner after introduction. It was not unusual for an engine to consume as much as 1/ltr of oil in 500-750 miles. Porsche initially denied this was a problem, but combined with the heavy usage - oil was found to be pooling in the bottom pipe from the turbo to intercooler, and in some cases fouling the intercooler.
In 2013 Porsche issued a Workshop Bulletin: WC55.
This campaign was later extended to cover 2013 models to June 2013.
Since this is not a "RECALL" - NHTSA can't force this to be done, and Porsche does it at their discretion. But it can be seen to be an emissions issue, and emissions warranties are either 70,000 to 80,000 miles and varying time. People have succeeded in getting this covered by dealers even when out of warranty. The action replaced the oil separator in the bank-2 valve cover with a new design.
Doing this has frequently taken the turbos from being oil burners to using virtually no oil.
Originally Posted by TrueDelta
NHTSA ID: 10051876, TSB ID: SB-76-12
WC-55 replacing oil separator. porsche. model years of 2013 also included. updated 6/28/13. models 2011-2013 cayenne s, cayenne turbo.
Brake Pedal Clip - all 958 models, 2011-2016
Brake Pedal Clip - Porsche RECALL AG02
Apparently is this clip was missing the brake pedal could move sideways on the pivot and jam or fail to actuate the brakes.
Originally Posted by Porsche
Porsche Cars North America, Inc. (porsche) is recalling certain model year 2011-2016 Cayenne vehicles manufactured april 28, 2010, to january 11, 2016. the brake pedal pivot pin may be missing a circlip, allowing the pivot pin to move and the brake pedal to dislodge.
If the brake pedal dislodges, the driver may not be able to apply the brakes, increasing the risk of a crash.
Porsche will notify owners, and dealers will inspect the brake pedal assembly circlip, installing any missing circlips, free of charge. the recall began on july 8, 2016. owners may contact porsche customer service at 1-800-767-7243. porsche's number for this recall is AG02.
Owners may also contact the national highway traffic safety administration vehicle safety hotline at 1-888-327-4236 (tty 1-800-424-9153), or go to www.safercar.gov.
Front suspension bolt - limited to vehicles manufacturered on 11/26/14-11/27/14.
This is a very limited scope recall, for cars manufacturered on 2 days in November 2014:
it is RECALL AF04
Porsche Cars North America, Inc. (porsche) is recalling certain model year 2015 cayenne diesel and cayenne s vehicles manufactured november 26, 2014, to november 27, 2014. due to a manufacturing error, the suspension alignment on the front and rear axles may not have been performed correctly and the screw connections of the camber, toe and caster may not have been tightened with the specified torque.
If the suspension alignment was incorrectly performed, vehicle handling could be reduced, increasing the risk of a crash.
Porsche will notify owners, and dealers will perform a front and rear suspension alignment, and check the screw connections for the proper torque, retightening as necessary, free of charge. the manufacturer has not yet provided a notification date. owners may contact porsche customer service at 1-800-767-7243. porsche's number for this recall is af04.
Headlights falling out - 2010-2012 All models.
This was a recall for a faulty headlight fastening system, allowing headlights to leave the vehicle on their own..
RECALL AC01
RECALL AC01
Porsche is recalling certain model year 2011-2012 cayenne, cayenne s, cayenne s hybrid, and cayenne turbo vehicles manufactured from march 8, 2010, through january 31, 2012 because the headlamps may come loose and detach from the fender.
A detached headlight could lead to loss of visibility and an increased risk of a crash.
Porsche will notify owners, and dealers will replace the headlamp locking assemblies, free of charge. the safety recall began on march 9, 2012. owners may contact porsche at 1-800-767-7243.
Porsche's safety recall number is ac01.customers may contact the national highway traffic safety administration's vehicle safety hotline at 1-888-327-4236 (tty: 1-800-424-9153); or go to http://www.safercar.gov.
Diesel Emissions Recall
Range of vehicles - all Cayenne 3.0L diesel vehicles in the US.
Originally Posted by Porsche Website
AG01: "Re-program DME control unit".
NHTSA Recall ID: Not yet available.
Description
Cayenne diesel vehicles were equipped with undisclosed Auxiliary Emission Control Devices which are not permitted by emissions regulations.
Safety Risk
Affected vehicles are not within U. S. Emissions Regulatory Compliance
Remedy
Install updated engine control module (DME) software and transmission control module ( Tiptronic ) software to bring affected vehicles into regulatory compliance.
Last updated Nov 06, 2017.
Description
Safety Risk
Remedy
At the suggestion of ledbette, I'm adding the following:
I recently purchased a 2017 Cayenne S and I'm trying to pull together a list of known issues. Here are a couple of things I've found that would be nice to have in a single place, maybe here, maybe in a separate sticky.
1. Transfer Case Warranty Extension - https://www.transfercasewarrantyextension.com, password DRIVEN
2. Speed Sensor Warranty Extension - https://www.wheelspeedsensorwarrantyextension.com, password SENSOR
3. There are a number of important TSBs on http://www.porscheproblems.com/model...sbs/index.html, including the TSBs related to the warranty extensions. The site links to documents stored in the NTSB repository. I'm not sure if there is an official way to locate these through NTSB directly.
4. One of the items linked on that page is a list of Advanced Technical Information bulletins (https://static.nhtsa.gov/odi/tsbs/20...68693-0001.pdf), which have technical details on how to solve some common problems. The awareness that these exist is definitely helpful for Cayenne owners.
