I installed a factory hitch/wiring on my 13 Cayenne last summer. The final step required taking it to the dealer to have the towing settings activated via PWIS. (I had to do this twice since the first time they didn't set the power to always on). Afterwards, if worked just fine.
When I connected my trailer to the truck last week, I didn't have any lights except for a very faint flickering on the running lights (no turn signals at all, no brakes). I then connected the trailer to another truck and everything worked just fine. And when I plugged a tester into the plug on my truck, it confirmed that the plug wasn't sending a signal. Any thoughts?
Porsche Trailer light module needs to be reset with piwis. Have them set it for incadesent lights and use a incadesent to led convertor when the trailer has led lights. If they set it for led there is no convertor for led to incadesent trailer light so the trailer light module goes into self protect mode.
If this is not it, check the fuses and then the grounds. Probably should check these first.
I don't think that would work with my trailer - I still need to power the brakes and that requires a 7 round. Seems like a perfect solution though if you only need a flat 4 (uhauls, maybe other trailers with surge brake?)
I am planning on buying the factory tow package from Suncoast and doing the install myself (having the dealer program it, obviously). Did the kit you used include instructions, or did you find them elsewhere? There's a good video online of installing the hitch but the wiring harness and module installation give me pause.
I didn't find the wiring too difficult, but I would suggest taking your time removing the interior panels to get access to the wiring. There was one really stubborn fastener that I couldn't get off and ended up working around it to the detriment of fitment went I went to put it all back together. I ended up replacing some of the fasteners to make it fit like it should. Interior trim tools are a must. The hitch itself was very easy - although figuring out how to get the bumper off was a little more difficult. You have to remove the wheel arch moldings; it feels like you're breaking it, but it's pretty flexible. Once you do that, it's pretty straightforward - lights do have to come out if I remember correctly. And don't forget you have to get it programmed via PWIS. My (NYC) dealership charged $200 which I thought was insane - and they also forgot to make sure the power was always on, so it required a trip back. (This is important if you want to use a Tekonsha RF instead of installing a brake controller inside the cabin). And clearly the incandescent to LED converter is also a must, but it's interesting to note that they don't show the application fitting MY13+ Cayennes. I'll know more when I get mine in a couple days ...
