Cayenne phone holder
I have hated every vent mount I have ever tried, and I don't mind having the phone down low. I figured it was time to try a magnetic mount. That led me to this:
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
$15 is nice too!
Now, to mount it, I fabbed up a simple length of aluminum channel. This provides the flat surface for the mount to stick to. I used a couple of zip ties to attach it, so totally removable. Could be much neater with a larger channel and some kind of bolt up clamping action, but this is probably yet another of my prototype builds that never gets to version 2.0. Rock steady, grabs and releases the phone in an instant, and fairly unobtrusive.
$15 is nice too!
I just put a proclip in my 958. Love it!
I had been using one of the air mounts on the vent in the Spyder, but it kept flying off around corners (not cool with the top down!). Figured I'd try out the proclip in the Cayenne and have now ordered a second one for the Spyder.
The benefit of just clicking it into the built in power and it not moving around outweighed the lower location IMHO. Oh - and it no longer fries my phone if I have the heater on and forget to close the vent
Received 1,160 Likes
It's difficult to see the A/C temp, but I usually keep them all synced, so I look at the passenger display when blindly adjusting the temp.
Proclip makes a reversed clip for the other side of the center console. I just installed mine on the same side as Dalema. I was afraid the passenger side would be too far of a reach.
Would be nice if the phone mount incorporated wireless charging (inductive) - it's all I use on my Motorola Droid Turbo-II. The microUSB is (IMHO) an engineering abortion designed for failure.. (and I've had enough of them fail) especially when put in a fixed position requiring the phone to be slid down over the connector. Didn't see that option on their website.
FYI, I ordered mine on Tues. (10/25) and received it on Sat. (10/29) using USPS Priority Mail option. I had also received an "on back-order" email the same day I ordered, so maybe that slowed it down a little.
http://amzn.to/2fsgrCy
It uses the standard sized ball mount socket on the back. So you have to put one of those onto whatever mount you're using. Lots of cradles work that way, either the ball or the socket on the back.
Just loosen the collar behind the mount and remove it from the suction mount arm. Arkon is another vendor that makes some nice double-T-slot mounts to allow quick removal of everything but the base.
Put this on the back of the mount:
http://www.arkon.com/product/AP2T17M...rmin-ball.html
Then put this on the bracket:
http://www.arkon.com/product/AP032SM...ter-plate.html
Then you can pop the whole thing off the dual-T leaving it relatively flat and feature-less looking.
There's a ton of ways to mount gear. Arkon has quite a lot of other brackets and the like.
I prefer a mount that keeps the phone higher. I really don't like the position of the Pro Clip one down on the console. I've used this one in my Grand Cherokee and greatly prefer that kind of location.
Are there no other higher-mount options for the 958? I'd prefer one that didn't require screws into material or glue.
THIS is the one I'm using for our Samsung S6 and S7 phones.
Thanks for catching that error. I edited the post to correct it.
The Qi-capable one is a lot more expensive. But it really does work effectively and is easy to use. Just squeeze the left/right tabs to expand the clamp and pop the phone into the bracket. The clamps will stay extended until you push the phone into the bracket. There's a tab that pops-in that releases the clamps to securely grab the phone.
At home we've got a couple of these:
http://amzn.to/2fLv1sN
My only complaint is it could be just a slight bit longer/taller. My S7 in a case tends to tilt back a bit if you try to use the top part of the screen while it's resting in the cradle. But it'll also charge my Nexus 7 table if I rest it there horizontally (even while in the case).
Here's some pictures of what I'm trying.
The first is an iOttie wireless charging cradle using their extending arm suction cup mount. It tends to sit the phone a bit too high for my liking.
The second is that same mount but attached to long, flexible mount, also via suction cup. It also includes a little stand to help brace it. This I saw in a fellow PCA member's Cayman. The ball on the end of the mount is a standard 17mm Garmin-style. The iOttie fits on it quite nicely.
Ignore the USB cable snaking along the dash under the gauges. I plan on getting power from the left fuse panel once I finalize the mount's position.
I'd rather have some kind of bracket that's more securely attached to the dash instead of a suction mount. Pro-Clip and other have made various solutions like that for other cars, but nothing other than the console position for the Cayenne. I'm of the opinion there's enough gap in the binnacle seam to allow for a bracket to tuck in there. The question is what to do on the outside edge. The air vent has a seam but it seems too tight to wedge something in there.
Anyway, just thought I'd share.
Basic Sponsor
Two words - A-pillar. Is it two words?
T-Design9 : Mods and ergonomic accessories bespoke designed for Porsche cars
Memory Modules : remember SC **** settings; A/S/S, PSE, Spoiler, Sport/+ buttons
Phone Mounts : keep your phone up and close and charged
Cupdholders, Sunglass Holsters and more at T-Design9.com
