Brake pads
I tried the Hawk LTS which have been good for me on other trucks - they definitely dust less but they don't stop nearly as well as the stock pads and will get replaced with something else next time.
I'm pretty sure multiple companies supply the pads with the list above being the big ones. I've never been able to verify that the pads you buy from Pagid/Brembo/et al are the same ones supplied to Porsche. I've had mixed results in the past with OEM companies supplying pads that looked and felt a bit different than OEM. I've seen similar posts from the 996/7 guys, and even some of the tuners. Some surmise that Porsche gets a special sauce from the brake companies, and the pads those companies sell directly aren't that same blend.
For that reason - I stick with OEM Porsche pads - but I'll take the dust for the consistent stopping.
Tons of choices.
Front
http://www.paragon-products.com/Brak...351.939.14.htm
Rear
http://www.paragon-products.com/Rear...0.615.415h.htm
Front
Rear
Your Porsche Parts Superstore
Parts | Tech-Session | Facebook | Youtube
Jason Burkett
Paragon Products - Porsche Parts & Accessories*- 800.200.9366
Tech Session - Porsche Tech & Info*- 361.289.8834
jason@paragon-products.com
Jason Burkett
Tons of choices.
Front
Rear
Front
Rear
Which brands shown in the link are low dust and have long pad life? On the Nissan I owned in the past, it would take 1-1.5mo to accumulate as much brake dust on the wheels as my Cayenne eHybrid does in two weeks. The car had 80Kmi on it and had not needed a pad replacement yet. Granted the braking performance cannot compare, but it's mostly my wife driving the car and she doesn't go above the speed limit, much less brake repeatedly from high speeds. Plus the rotors are large enough to compensate for long life pads and performance should still be sufficient for daily driver use.
I have the Posi Quiet pads (http://www.autoanything.com/brakes/77A4364A3935685.aspx) on my stoptech BBK that's on my infiniti G35 and they have worked well. Anything similar for they Cayenne?
Thanks!
