Ticking 957 turbo
#76
Thanks for the feedback. I have a few questions.
What specifically would the repair options be?
How much does a new short block from porsche cost?
I've read the thread on 'cayenne engine replacement' and I've seen the replacement range from 10,500 to 27,000. Why is there such a wide margin.
As far as rebuilding with flat6 or 928 motorsports, approx how much does that cost all in?
What route are you taking?
Thanks for all the info in this thread, its been very informative.
I am rebuilding my engine in house. Fortunately I have the resources to do so. LN engineering is repairing the block, I will be doing all other work. My total cost, not including labor, will likely be in the 15k range.
Porsche quoted me about 16k for the re manufactured short block. This option was pretty much out of the question at that price, since I truly believe the same issue could manifest itself again in the future with the Porsche parts.
This almost hurts to type, but I would expect to budget 20k-30k to have it repaired at a reputable shop or dealer. When I spoke with the guys at Flat-6 they were booked out over a year.
Feel free to shoot me a PM with a number if you want to chat. I'd be happy to help any way I can. If you have a very strong relationship with the dealer, they may be willing to work with you, but it will still be painful.
Maybe you will get lucky when they investigate further. Additionally, the majority of the scoring on mine was below the top ring, so the worst of it is not even visible on the bore scope. If there is any evidence when they scope it, it will look worse when it's torn down.
Best of luck
#77
Not to stick my pecker in a beehive here... but why can't one rebuild their own engine? Even at the cost of 100% custom oversize slugs, you're not talking a ton of money for a refresh, especially if you R&R the heads as complete assemblies. Sure its not an easy weekend job, but all this talk or repair prices makes it sound like the thing was originally assembled by space aliens.
#78
Granted, I'm doing a full and proper rebuild, including a full refresh of the heads, turbos, and planning an oil pump replacement (almost 1500.00 alone).
...you're right, they're just engines
![thumbsup](https://rennlist.com/forums/graemlins/bigok.gif)
#79
I was about to ask just that question... Ugh. Certainly out of the ordinary for the regular jobber but I can't seem to get away from the damn things! Although all the other Nik motors I've screwed together were V6s with huge holes in the cylinder walls. lol.
and 8ish is the number that was rolling around in my head for a full build, not far off of where you are.
#80
and 8ish is the number that was rolling around in my head for a full build, not far off of where you are.![thumbsup](https://rennlist.com/forums/graemlins/bigok.gif)
#81
How about getting a totaled 957tt and swapping an engine? Or just buying an engine that you scope first?
If you do it at a dealer, they will charge for the time the techs are picking their noses, taking leaks and dumps... They make it sound just like was mentioned before - some sort alien craft. Forget about it, the engine can easily be pulled in about 8hrs by one guy and te actual pulling requires another tech's assistance. My indy could probably do it blindfolded while drunk in 5hrs by now
I'd just source an engine from some salvage yard and swap it. Easiest, least time consuming and cheapest. And you can still easily part out your current engine and earn some serious money back if you have the time & space to keep parts.
#83
Yep. I can't afford new ****, I gotta buy the stuff that everyones scared of and make it run (and last). Hopefully it doesn't come to that with the Porsche but its nice to see the options out there.
I knew I liked this guy
![rockon](https://rennlist.com/forums/graemlins/rockon.gif)
#84
#86
They exist, but it would be best to find a totaled car like the one above to part out. This one is pretty typical of what I found when I was debating new vs used...
http://m.ebay.com/itm/2010-Porsche-P...619?nav=SEARCH
Since I can perform all the labor, I didn't see a cost savings going used.
#88
I noticed a new noise in the drive thru last week. When i brought it to the dealer for an oil change i mentioned it, but my service advisor didnt seemed concerned with it. It seems too loud and noticeable to be 'normal' engine noise, but im no expert.
Anyone have a similar noise or problem. Is this just how they sound or should i bring it back in to the dealer?
Well. Got the call from the dealer... Badly scored cyllinders.. All of them. I change the oil at the dealer every 5k and add it in between when needed.
Only thing i can think of that would cause this was driving once in -6' weather on vday.
![](https://cimg6.ibsrv.net/gimg/rennlist.com-vbulletin/640x480/image_07bab0ed7a4eafb249e5662c80247b6b6cfe62d9.jpeg)
![](https://cimg7.ibsrv.net/gimg/rennlist.com-vbulletin/640x480/image_262c598c834d7059de911fda86d7b5d05cbfd93f.jpeg)
Now my question for those who have rebuilt blocks.
I am probably goin to get the rebuild from 928 motorsports/us chrome with nicom/nikasil coating and new pistons.
How much time should i expect the indy to bill for tearing down the engine, crating it to us chrome, then reinstalling it.
Also what else should i replace or fix while im there with the engine out.
Thanks,
And beware of ticking motors
