Hydraulic hose clamp
Any idea what the clamp that holds in place the U-shaped hydraulic line underneath the oil filter (on a 957) should look like?
When changing the oil on mine I found that some smart mechanic/previous owner decided to use cable ties, looking on the internet it seems the 955 is different to the 957 in that access to the oil filter is not blocked by this pipe with the 955.
Take care of those zip-ties! When my Indy changed oil to my CTT they let it somehow lose and after 2 weeks while a spirited drive I had a chassis system failure.
Somehow the lose hose was damaged and lost all the hydraulic fluid on the road. Save yourself the trouble.
The bar that holds the lines are attached to the engine by two rubber vibration dampers. The ones that have a stud on both sides.
Mine was flopping around when I did an oil change. It appears the small oil leak we all have along with needing to remove it for each oil change breaks down the rubber from the stud and then rips
part is called bonded rubber buffer- 95534363810
http://www.jimellisporscheparts.com/...ssembly=475654
This is just what I need - thanks!!
From what I understand its the power steering line that is hanging down and I need 3 of the bonded rubber buffers along with 3 M6 nuts, presumably the other sides screw into the sub frame.. or whatever it is hopefully I don't have that missing as well!
Shall remove the under-trays (again) and have another look.
Thanks for the help guys
