Top engine torque mount question
Hey everybody,
I'm doing spark plugs and coils on an 04 Cayenne Turbo and i'm having an issue removing the bracket that obscures the coil on the passenger side of the engine (the one the torque arm bolts to). The lower two bolts are just turning but not coming out. Any suggestions? Thanks.
Tony
Tony
From the DIY at Pelican Parts:
You’ll now need to remove the mounting bracket. Begin by removing the two E10 Torx bolts (green arrows) holding the bracket at the bottom. Also remove all four of the T30 Torx screws holding the coil pack covers to the cylinder head.
http://www.pelicanparts.com/techarti...eplacement.htm
Hey everybody, I'm doing spark plugs and coils on an 04 Cayenne Turbo and i'm having an issue removing the bracket that obscures the coil on the passenger side of the engine (the one the torque arm bolts to). The lower two bolts are just turning but not coming out. Any suggestions? Thanks. Tony
Hey everybody. Thanks for the input but I'm an idiot. I was using the right size socket (e12 if I remember) but it was too fat for the hole so instead of turning the bolt it was binding on the walls. Sorry and thanks again :-)
