How do you know if a 955 Turbo has the larger brakes?
Lifetime Member
Lifetime Member
When I was looking at breaks for my Cayanne S,I noticed that there were two different types of braids for turbos. And the price difference between the two was very substantial. How do you know which ones a turbo has if you're looking at purchasing one? Any dead giveaways?
The larger Brakes (380mm) only came with the E81 performance package (basically the same as a Turbo S). They also had larger intercoolers and a list of other items. Check the options sticker in the trunk. It will also be listed separately on the option sticker as I1LH, which is 19" Brakes which is a misnomer, it actually means the smallest wheel you can use is a 19" wheel to clear the rotors. Oh, the easiest way is to look at the Front rotor and if it is a 2pc rotor with a Aluminum hat bolted to the outer cast iron ring it is either a E81 option, a Turbo S, or someone has upgraded the front brakes to the larger OEM or aftermarket. Once again, only the E81 (Power Package) or Turbo S came with the larger brakes, not available separately.
Lifetime Member
Lifetime Member
