Odometer Reset
Old 12-31-2014, 04:33 PM
porsche3.2
porsche3.2's Avatar
Default Odometer Reset
Hi,
When I press my button it does nothing.
Any help would be appreciated.
Also do I need this working to reset the service message?
Old 12-31-2014, 04:34 PM
wrinkledpants
wrinkledpants's Avatar
Press and hold. If that doesn't work, it's probably broke. You need durametric or a trip to the dealer to reset the service message.
Old 12-31-2014, 04:37 PM
porsche3.2
porsche3.2's Avatar
If its broke, how can it be fixed, can it just pull out, or does dash need removing?
Old 12-31-2014, 04:41 PM
loxner
loxner's Avatar
Mine can be a PITA to get it to reset. Sometimes takes 6 or 7 presses from different angles before it finally works.
Old 12-31-2014, 11:26 PM
Slow Guy
Slow Guy's Avatar
Originally Posted by porsche3.2
Hi,
On my '06 S I had it happen twice (as in nothing I could do to get it to reset), since it was under CPO warranty I took it in and dealer had to replace the instrument cluster both times. I hated taking it in for such a piddly problem but I used the trip odometer and expected it to work. Was later told that mine was one of several vehicles that had the problem.
Old 01-01-2015, 12:46 AM
scottl951
Formerly 'slevy951'
scottl951's Avatar
The button goes to a long (1" ish) thin stick that presses a button on the circuit board in the instrument cluster. The stick is, for some reason, missing the button the circuit board in my opinion. I doubt the switch on the board is bad. Mine is doing the same thing. Insturment cluster has to come out and apart to fix. Crappy design.
Old 01-01-2015, 04:08 AM
porsche3.2
porsche3.2's Avatar
HNY!
Just read these, looks like you can pop off the button and fix the button.
https://rennlist.com/forums/porsche-...-the-dash.html
http://www.renntech.org/forums/topic...ill-not-reset/
Old 01-01-2015, 07:12 AM
porsche3.2
porsche3.2's Avatar
I just pulled it off and pressed the plunger, with my finger, it reset!!
Old 01-01-2015, 11:04 AM
porsche3.2
porsche3.2's Avatar
I've read that on 06 cars, this option to reset was disabled :-(
Old 01-01-2015, 12:56 PM
scottl951
Formerly 'slevy951'
scottl951's Avatar
HNY!
Nice find! I'll give this a shot and report back.
Old 01-01-2015, 01:19 PM
porsche3.2
porsche3.2's Avatar
Just hold it at the edges and pull, takes a but of pressure, but pops out easily in and out :-)
Old 01-01-2015, 05:57 PM
scottl951
Formerly 'slevy951'
scottl951's Avatar
Popped them off and pushed. IT WORKED! The buttons are functional. I'm surprised all that is keeping this from working is the 'outer' button. Since I had to switch clusters earlier I had spares and all is good now. Thanks very much for keeping me from removing the cluster again!
Old 01-02-2015, 03:49 AM
porsche3.2
porsche3.2's Avatar
No worries, glad it worked.
We are all friends here, and I love this forum :-)
Quick Reply: Odometer Reset
