my code is Fault, All-wheel Drive Electronics does changing the transfer case servo solve my issue too? (dont say i gotta change the battery cuz i tried that and it didnt work)
How is your battery? Surprisingly, a weak battery will trigger this error. As the battery starts to fatigue and approach end of life, the dip in amperage during peak load like starting will trigger the error.
bro if its not the battery what do you think is the case with mine
