homelink garage door opener
this one has the porsche garage baffled too. cant program homelink, although the garage door manufacturer website explicity states it works with homelink and that it operates on a fixed frequency code basis (not the changeable code system, which would require additional programming steps). i tried it, friend tried it, porsche tried it. any tips from those who overcame similar difficulties trying to program homelink in their cayenne? in a honda, programming the garage opener takes literally 10 seconds, you can stay in the car the whole time, and doesnt involve 7 steps (like porsche, when it even works at all). porsche dealer said they often have problems with programming homelink-it just isnt user friendly. yet another option i start to regret... thanks.
We had no problem, but for our garage door, there is a "learn" button on the garage door assembly.
Open panel on garage door assembly (yes, the one attached to the motor which opens the door!)
Within 20 seconds push and hold the homelink button you want to have open this door.
When the garage door light flashes, the opener is set to work with the Cayenne homelink button.
Hope this helps!
Hope this helps!
Hope this helps!
Hope this helps!
1) Park the Cayenne in the garage, directly below the opener as range can be an issue when programming. Get a step ladder, to reach the opener unit's button.
2) Check documentation of garage door opener -- may give you hints, or steps unique to your unit.
3) If that doesn't work, erase setting, as described in the manual -- think you hold the #1 and #3 buttons at same time, and try again.
My openers are the roving code type; your fixed one should be easier to program.
Good luck.
I have tried several times and have not been able to get mine to work either!!!
I dont know why everthing has to be so complicated on Porsches. BMWs are so much easier to program. Especially the memory seats. Have not even tried that one yet....
homelink worked fine for me on a genie opener (learn button) and surprisingly easy to connect with a USAutomatic electric gate. I think the homelink as been much improved over the last time it was equipped in a car I had.
My cayenne is a 2004 and for some reason I had to fight it. Just sit in the car and keep trying, it should work eventually. I was literally in the car two hours about to die of carbon monoxide poisoning before I got both garage doors opening in my garage. Mine are the roving type so maybe that is why. My advice is just don't give up. I probably went throught the programming cycle 50 times before the first door started working. Then another 100 before the second one picked up. It sounds so simple in the instructions but it took me a lot of tries. The good news is ever since I have had no issue and the doors open every time. Good Luck.
I just did mine a couple days ago....I programmed all three buttons for my garage. The first worked just like the manual stated.....the second and third were harder to do.
Like someone said...you do have to press the learn button on the garage door motor itself. I tried without pressing that and the light blinked still (the light supposedly confirming it learned the code) but it didn't work.
I had a heck of a time getting mine set up. I found a thread here that said that if you have a newer opener you have to do the synch several times to account for the rotating security codes the opener uses. So, I did the 'Learn/Homelink' sequence several times (six, I think) and now it works like a champ.
Since yours is fixed code, seems like you should be able to just push the console button, then go to the front of the vehicle, and push the opener clicker, until the front lights flash.
The brand spanking new diesel in " virgin " white was positioned right in front of the bay for the garage door installer to program home link as the boss and I couldn't figure it out. Next thing you know, I come over as the guy is sitting in the drivers seat and I see he's bleeding on the arm!!!!!!! I start going crazy as the back rest has a patch of blood on it!!! Oh I lost it big time!!!!!!!!!!! I ran into the house and wetted a terry cloth towel in cold water and ran back out to attempt to stop the catastrophic damage! I told him to get away while I dabbed the area over and over again. Thank my lucky stars but the entire 1 1/2 inch diameter spot came completely clean! Ohhhhh man, I was ready to have a coronary! That night I drank heavily as the anguish still lingered. Disaster averted and doors are programed.
Just a thought, did you deprogram the default codes that are put in by Porsche? On my new one, I had to deprogram first then reprogram and it worked fine. It would not do it by just trying to reprogram.
