Are the sections of the overhead console replaceable?
Old 07-09-2013 | 12:31 PM
Jeremy's Avatar
Jeremy
Default Are the sections of the overhead console replaceable?
I am installing a Tooki bluetooth microphone in the overhead console. I was intending on modifying a donor console in the section where the park assist button is located and was surprised to see pics of circuit boards on the backside of the console (very different from the same process in a BMW). Can sections of the overhead console be popped out and swapped or is it all just one piece with seperate circuit boards fastened? Many thanks in advance for your reply -
Jeremy
Old 07-09-2013 | 01:31 PM
XR4Tim's Avatar
XR4Tim
Almost every piece of the overhead console is available separately.
Old 07-11-2013 | 09:53 AM
Jeremy's Avatar
Jeremy
Many thanks for the reply. I want to make sure I was clear with my question. I do not have a blank and park assist button portion on my console, it is just plastic with the grate. I would like to take the blank and park assist portion of the console from a donor console and affix a microphone to the blank and then swap that portion into my existing console (e.g. My existing console would now have the park assist button section with microphone). I can't swap the console in the entirety because my donor console will likely have issues so that i can get it cheap. Will this work? Thanks -
Jeremy
Old 07-11-2013 | 05:52 PM
XR4Tim's Avatar
XR4Tim
Yes, if I understand you correctly, that will work.
Old 07-11-2013 | 11:59 PM
Jeremy's Avatar
Jeremy
Great - many thanks!
Old 07-12-2013 | 08:38 AM
stormin48061's Avatar
stormin48061
XR4Tim, if the overhead console parts are available individually, can you point to diagram/part listing for the individual parts? my eye class holder tab broke and would like to replace, thanks.
Old 07-12-2013 | 10:12 AM
XR4Tim's Avatar
XR4Tim
Sure, here you go:
Old 07-12-2013 | 10:16 AM
Jeremy's Avatar
Jeremy
I would recommend you do a search on ebay for "cayenne overhead console" - there is a seller who uses the parts diagram as part of its auction listings
Old 07-12-2013 | 10:17 AM
Jeremy's Avatar
Jeremy
xr4tim is quicker on the draw - my many thanks to him as well
Old 07-15-2013 | 11:41 PM
stormin48061
thanks!
Quick Reply: Are the sections of the overhead console replaceable?
