Coolant pipe replacement in Atlanta
Scared to Look
Yep Im smelling antifreeze. I searched coolant pipes Atlanta and got nothing. Any suggested shops?
Aside from the smell of coolant, are there any visible indicators of the pipe failures? I am looking into a used CTT and a service advisor from the dealership that the vehicle was serviced at says the pipes weren't done.
Former Vendor
I would make sure it's your coolant pipes leaking first, we do over a DIY if your ambitious and have the time to do it. For more information on the Click Here.
Scared to Look
I am not sure. I just started smelling collant, and added about a half gallon last night. Its been raining so I cant see if its dripping .
I would be adding (distilled) water not coolant if you suspect a leak, no sense adding more of that stuff to crust up on your engine if you don't need to. It's not going to be either too hot or too cold in Atlanta this time of year.
If your smelling the fluid but not seeing any leaks you need to stop driving the car especially if your filling it with large amounts of coolant. If it's the coolant pipes than you are most likely filling the valley of the motor and that's going to destroy the starter and possibly the rear motor/transmission seal.
Talk to John Vick.
Lanier Motorwerks
1960 Skylar Hill Dr, Buford, GA
404-889-0216
They have done several coolant pipes there and worked on many Porsches.. They have a master porsche mechanic employed there.
Let him know Tommy with Cayenne sent ya.
Lanier Motorwerks
404-889-0216
