Cayenne S DIY Oil Change Photos
Changed oil on my S and there seemed to be a lack of photos illustrating the location of the two drain plugs and the oil filter. Hope these help.
About to do this...thankyou. I'm assuming both plugs are the same.
What year is your Cayenne?
Actually, I just searched the forum and found this great write up....
https://rennlist.com/forums/porsche-...-pictures.html
Thanks! I've had my 2004 since new. I saw the same great write up but it was for a turbo and they did not remove the second oil plug. These photos help clarify a bit. Good luck and yes both plugs are identical. Love that Shark!
Yes, I noticed that about the second oil plug. I've have read that you are indeed correct in removing both plugs. I'll certainly be doing it!
Thanks for your comment regarding the shark...I've owned it for 10 years now. Know it inside out! I rather like the black machine in your avatar too!
