Please HELP track down my coolant leak
I recently change my pipes and I checked a kit out from Advance Auto Parts that includes an adapter that will expand to fit any opening. However, you will need someone to help hold the fitting in so that the pressure does not pop the fitting out while you pump the handle.
do you rmemeber how much the deposit was?
So from what I can see its holding pressure at 15psi. Does the water pump only leak when running? I have kind of thrown in the towel and just replacing the water pump and gasket as preventive maint anyways and putting everything back.
Yo VIP - did you replace the water pump and gasket... and did that do the trick??
I'm in the exact same boat now. Tyring to ID the exact spot of the leak...
Thanks.
Thanks.
Good point, because the coolant only drips when warm. Could the splash on the SAI pumps means the alternator is sending coolant drizzle upwards? I think I am gonna drop the belly pans and start from there....
