Cayenne S 2006, Rear Air
I brought a 2006 Cayenne S and absolutely no air blows through the rear vents even when I close the front vents. My dealer tells me that the car was manufactured that way. I feel that I am being told wrong information. Why would there be 4 rear vents with no intention of blowing air through them.
Is this true, that the Cayenne S 2006 model was built not to blow air through the rear vests?
Thank you,
Frustrated as Can Be
Thank you,
99% worthless. if you turn the front down to maybe 1/4-blast, and turn off the dash/speaker thingy, then a small puff of cool air will waft its way through to the back.
Received 1,150 Likes
Interesting, mine blows air out the rear center vents just fine (and it's not the 4 zone system.) In doing some wiring installation, the ductwork to the rear vents runs through the console.. and it's made of a foam composite, which could be easily compressed and blocking off the airflow. That's what I'd look at first.. I believe the foot level vents use the same sort of ducting..
