Front license plate bracket install interfering with PDC
Has anyone seen this happen before? I just installed a bracket (wifey got a ticket for no front plates). There are no wires that run behind the bumper where the 4 screws are screwed so its not a wiring issue.
I removed the bracket, tested the car and everyhing went back to normal. I put it back on, it starts to beep everytime I come to a full halt, like the system is malfunctioning.
Any ideas??
TIA
Any ideas??
TIA
Yes, I ended having a decal made of my front number plate! In oz, our Euro style plates are wide and seem to set the sensors off. The only other alternative was to lower the plate but it looked all wrong.
I can't believe Porsche sells a bracket that interferes with a system. My state requires I run a front plate and this constant beep at full stops is going to drive me nuts. There has to be a fix...
Orantes, unfortunately we have to run state mandated plates and don't have any options on adjusting it's size. Looks like the sensors are acting up less and less. Let's keep our fingers crossed.
Thanks for your suggestion.
Super Moderator
Needs More Cowbell
Needs More Cowbell
Did you install an OEM front license plate bracket, in the defined OEM location?
Did you check Loren's site to see if there was a F/W update? I can't remember if there was an update for this module or not.
If it is a CPO vehicle and the front bracket mount/location is OEM, then your dealer should be able to help. If not, then the dealer might fall back on "aftermarket modifications" ... depends on the relationship between you and your dealer.
Odd, first time I've heard of this problem in the P!g Pen ...
It is an original Porsche license plate bracket, in its proper factory location. I did speak with the dealer and they wanted me to bring it in. I didn't see it acting up much in the last day or so, so I decided to skip.
Dealer has been great (slipping a few bucks to the service advisor always helps). They swapped my work steering wheel for a brand new one under goodwill.
I will check and see if the problem goes away. I did check Loren's site and what I found there was related to the 1st gen trucks.
What had me upset was, I had to drill holes and when I removed the bracket to test, the problems went away. Wifey rather have holes in bumper than get a ticket! Argh!!
Super Moderator
Needs More Cowbell
Needs More Cowbell
Eric at Bumperplugs can help with the holes, no problems there.
It is entirely possible that you have a faulty sensor assembly/alignment ; both of which would be fixed with a warranty replacement.
Just out of curiosity, if you replaced the (metal) license plate with one made of cardboard (non metallic), do you get the same result?
It could be possible that its a faulty sensor. It is currently not acting up, but I am having it checked out today. My CPO warranty runs out early next yr. Want to make sure I get everything sorted out before that.
I could possibly test it by removing the fron plate to see if its the plate or the bracket.
Raj
As per dealer, it is an issue with 08's. Looks like Porsche did not anticipate their owners on running license plate frames. The dealer removed the frame as the fix.
09 don't have this issue..
Regards.
Raj
Regards.
Raj
09's have the license attached to the center of the grill. No drilling required.
Do you have pics by any chance?
A few pics of a front bracket on an 08.
http://cgi.ebay.com/ebaymotors/2008-...item3a7785b6d6
My SUV is 100% identical to this one! Mine has Park Assist though, so additional sensors on each side.
http://cgi.ebay.com/ebaymotors/NAVIG...item3cc88e8650
Super Moderator
Needs More Cowbell
Needs More Cowbell
So you would just drive around with the service receipt from your dealer stating that you can NOT run a front license plate...
Bizarre, even for the P!g Pen.
If the dealer is correct and if Porsche did indeed configure/sell a US vehicle that does not allow for proper operation when equipped with (legally mandated) front license plates when installed on the OEM mounting bracket, I would have expected at least a TSB if not a mandated recall/fix.
