Replacement Tires
The V8 Porschephile
As far back as the early '90s and before N-specification, Porsche would annually test a series of tires from various manufacturers. They would rate each tire on different Porsche models and post their recommendations as to which tire worked best on each specific vehicle.
I have yet to get a logical response from any tire manufacturer's rep as to whether or not there are considerable differences between two identical models of tire (one N-spec and the other standard) of the same brand to justify the hike in price.
Last year, a Pirelli rep had told me that the N-spec P-Zero has many changes to it over the standard P-Zero. Changes such as bead design to better fit the Porsche OEM rim, modified placement of the steel belts, custom rubber compound, etc... that better work with Porsche's suspension setup.
For now, all I can say to you is that unless you are tracking your Cayenne and using it to it's fullest degree, N-spec tires are overrated for most of us who use our trucks to commute daily to work and back.
Personally, I believe that there's too much undocumented hype on the N-spec; especially since the cost is easily 20-25% higher and we don't drive or track our Cayennes like a GT2 or GT3 owner would.
BTW, Tire rack has an excellent write-up on N-spec tires here:
http://www.tirerack.com/tires/tirete....jsp?techid=26
In the end, the choice is yours. Just remember that if you only replace one or two of your tires with new, they must all be N-spec tires.
Thanks for the info Andy. Has anyone got any feedback tires in the 21in size. I know the selection is limited and the price is crazy, but is it worth the extra 100-150/tire for the Michelin or the Yokohoma tires over Conti's or P0's.
George
George
A
"For now, all I can say to you is that unless you are tracking your Cayenne and using it to it's fullest degree, N-spec tires are overrated for most of us who use our trucks to commute daily to work and back.
Personally, I believe that there's too much undocumented hype on the N-spec; especially since the cost is easily 20-25% higher and we don't drive or track our Cayennes like a GT2 or GT3 owner would."
The V8 Porschephile
George, if you do a search on this subject you'll find quite a bit of feedback that's been submitted.
Rocky Mountain High
FWIW - I like N-spec tires on my C4S. I use standard tires on my Cayenne. The Continental ExtremeContact DWS is the best tire I've ever had on the Cayenne. I like it much better than the N-spec Continental SportContact 4x4 tires that were on my Cayenne from the factory.
George
Rocky Mountain High
Hopefully so. P-Zeros are horrible for tread life. I had a set of Continental SportContact 4x4 tires on our Cayenne at one point. They didn't last quite as long as the DWS, but longer than the P-Zeros.
