Frustrated - Ceramic Brake Pads - 368mm - MY08-10 Cayenne Turbo
#31
For use on vehicles with 350mm rotors:
http://www.pelicanparts.com/More_Inf...25&SVSVSI=1086
Question #1:
Can someone please advise if these pads will work with my 08 Cayenne Turbo?
Question #1:
#32
Thank you 7 Summits. On this page on this pelican parts for 08 cayenne Turbo page i see hardware for the calipers but not for pads. Could you please point me to the pads hardware/kit or the names of hardware parts needed?
Also still not sure if aforementioned hawk ceramic pads will work. Also not sure if my factory rotors are 350mm or 368mm version. Thanks in advance for help!
#33
#34
Thank you both. For some reason Pelican Parts had the Hawk pads for 350mm rotors in the results even though I selected 08 CTT as my vehicle.
So I then looked at the Textar brake pad set which Pelican parts confirmed will work with my vehicle. However when I spoke with my shop that's going to install they said don't get Textar as they've had some issues with them in past being noisy.
So any recommendations on which pads to get?
BTW: if I need rotors I am thinking Zimmermann.
#36
358mm rear rotors?!
No worries. Thanks a lot.
For anyone else who finds this thread for the same information, here are the OEM part # , Pagid part #, and EBC Yellowstuff Part # for front and rear pads for the 368mm rotors and calipers on the MY08 Cayenne Turbo.
Front Pads:
Porsche Part # 955.351.939.63
Pagid Part # T1798
EBC Yellowstuff Part # DP41835R
Carbotech Part# CT1349
Rear Pads:
Porsche Part # 955.352.939.63
Pagid Part # T1863
EBC Yellowstuff Part # DP41836R
Carbotech Part# CT1350
Front Pads:
Pagid Part # T1798
Rear Pads:
Pagid Part # T1863
so I called Porsche with my vin and I was told I have 358mm rear rotors… 🤬… will the rear ebc pads fit that? Just bought them realizing after that I cannot cancel my order lol.
#37
Front Pads:
Pagid Part # T1798
Rear Pads:
Pagid Part # T1863
Front Pads:
Pagid Part # T1798
Rear Pads:
Pagid Part # T1863
EBC Red Front DP31835C
EBC Red Front DP31836C
Pad Options for the 2008 Porsche Cayenne Turbo:
Front 368mm
EBC Yellow DP41835R
EBC Red DP31835C
Porsche 955.351.939.63
Pagid T1798
Carbotech CT1349
Rear
EBC Yellow DP41836R
EBC Red DP31836C
Porsche 955.352.939.63
Pagid T1863
Carbotech CT1350
I found the part numbers by searching for the FMSI ID "D1350 Red EBC" for the rears and "D1349 Red EBC" for the fronts.
I still have to get my calipers re-powder coated as well as order my pads and rotors still so it won't be a few more weeks since I mod slowly.
bobbyjimmy (08-26-2023)
#38
FCP lists more 368mm brake pads under the V10 Touareg 2008-2010 than the 2008 Cayenne turbo. They have the ebc blue, black, red and yellow listed
https://www.fcpeuro.com/Volkswagen-p...isc-Brake-Pad/
