Frustrated - Ceramic Brake Pads - 368mm - MY08-10 Cayenne Turbo
I did all of my homework, yet still coming up short. Having a VERY hard time find a good set of ceramic brake pads for MY08 Cayenne Turbo due to the upgraded stock brakes on this MY.
I wanted to go with Hawk, whereas they list 2 different pad numbers as compatible. However, both were not compatible :mad: Of the two threads I found that were related, both people aborted their search and put on the much more expensive / non-ceramic OEM pads. Stock Part # 955.351.939.62 . I have a new set of stainless steel brake lines, Castrol SRF brake fluid, and a Motive Brake Flush System just waiting for this to get sorted out. Does anyone know if any good options (besides OEM) for the 368mm rotors standards on the 08-10 Cayenne Turbos? Note: These are the bottom-mount pads for the red calipers. Minimum 18" wheel clearance. Update: Aftermarket pads are available from EBC and Carbotech. Part numbers can be found here for all options found in US. Correct Pad Shape - 368mm http://content.wse.by/parts/1_1172106/kawe_1345_00.jpg 368mm Rotor and Caliper http://www.porsche.at/html/hu/images/kbase/1/540.jpg http://www.who-sells-it.com/images/c...nne-000039.jpg |
2009-10 Turbos have different brakes than the 2008. In 2009, they adopted the brakes from the 2008 Turbo Power Kit as standard. This may be the key to your fitment issue. I'll look around and see if I can find a correct set of pads.
Originally Posted by XR4Tim
(Post 9430206)
If it helps, they have also resumed using this caliper in the Panamera. I believe both the Turbo and GTS are using the calipers. |
It looks like most of the aftermarket companies' catalogs aren't quite accurate. Textar does make a brake pad set for the '08 Turbo, but it's OEM replacement, rather than for performance. It looks like EBC Yellowstuff pads DP41835R are correct as well, since EBC lists a different part number for '09-'10.
Early Panameras do use the same brakes, but there is a VIN split, and the later Panameras use different brakes, making it all the more difficult to determine whose catalogs are correct. |
(Post 9430630)
Early Panameras do use the same brakes, but there is a VIN split, and the later Panameras use different brakes, making it all the more difficult to determine whose catalogs are correct. I know this is their track compound (Kevlar) with slight street use. Do you know how it will compare to the Hawk ceramics? FWIW, I think most people are hyper-sensitive to brake squeal, so unless it is exponentially louder, I am not worried about it. Just need good initial bite and manageable brake dust. Preferably, minimal dust. |
I have no personal experience with either Yellowstuff or Hawk pads. I did buy Hawk pads for one of my previous cars, but sold the car before I put them on. Looking at EBC's chart, the Yellowstuff pads have a high dust rating, which they say means the same or slightly more dust than OEM pads. I think you are right regarding brake squeal, and being that the Cayenne has noisier brakes than most passenger cars, I doubt high-performance pads will be much noisier, if at all.
(Post 9430878)
My OE brakes (just an S) only squeal occasionally (very minimal) but they're near the end of their life. I'll need to replace in about 5k mi. |
XR4Tim,
I think I might try the yellowstuff pads and take my chances with the initial bite and brake dust, over the OEM Pagid pads. Do you happen to have a link or part number for the matching EBC Rear Yellowstuff? Having a hard time finding it online since the EBC website is horribly dysfunctional. For instance, in their compatibility selector, they do not even list Porsche as a manufacturer. Despite having the correct front pads. I tried to call them as well, but they do not have a number listed online. Rear Pad - OEM Part #: 955.352.939.62 Pagid Part #: T1863 EBC Yellowstuff Part #: ???? Do you have another means to their catalog? |
DP41474R is the rear pad set. We have their catalog here at work.
(Post 9431207)
Are you 100% on your part number? Just want to make sure this is the final reorder. These catalog inconsistencies sure are confusing and frustrating :( |
Sorry, your number is correct. I'm not sure how I came up with the other part number.
Edit: I was looking at 2009 when I got that part number. DP41836R is correct. |
Amazon also lists as the rear for the Cayenne Turbo 08 only for Yellowstuff
(Post 9431238)
For anyone else who finds this thread for the same information, here are the OEM part # , Pagid part #, and EBC Yellowstuff Part # for front and rear pads for the 368mm rotors and calipers on the MY08 Cayenne Turbo. Front Pads: Porsche Part # 955.351.939.63 Pagid Part # T1798 EBC Yellowstuff Part # DP41835R Carbotech Part# CT1349 Rear Pads: Porsche Part # 955.352.939.63 Pagid Part # T1863 EBC Yellowstuff Part # DP41836R Carbotech Part# CT1350 |
The Porsche part number has been updated to 955.351.939.63
(Post 9431388)
