06 cayenne s door wont open
Premium Dealer
no no no, had the same problem, you go from the back of the door jamb and can release the latch, forgot how our dealer did it but had it unlatched in about five minutes, typical problem
That works because the cable adjustment is too tight and pushing on the handle gives it enough slack for the mechanical lever to reset.
Use this thread
https://rennlist.com/forums/diy-caye...rable-fix.html
remove the handle and move the adjustment block to the next groove over so the cable is 1 notch looser and you probably won't have to push on the handles anymore.
Use this thread
![bowdown](https://rennlist.com/forums/graemlins/bowdown.gif)
7th Gear
Thanks techbyte, I am glad my post has helped someone!….I realize it is not a permanent fix to the problem, but it does get the door open
It is oh so frustrating when you begin to experience this problem…
Petza914, thanks for posting that link….I gave it a look, and it looks interesting…I will investigate further and give it a try…I would love a permanent fix…I will write a follow up 👍🏻
