AWD/PSM Failure Messages
Super Moderator
Codes:
Porsche Stability Management (PSM/ABS8)
Current Fault Codes
2053:
Transfer box control module - Please read out fault memory, test conditions are not-completed, fault is not currently active and is not causing a DTC light
Level Control
Current Fault Codes
1772:
Signal lead for pressure sensor - Implausible signal, test conditions are not-completed, fault is not currently active and is not causing a DTC light
907
Load management operat. on vehicle
electrical sys./DME control module
Present
Current Fault Codes
2053:
Level Control
Current Fault Codes
1772:
907
Present
Super Moderator
I'm sure I can swap these modules out but I guess I need to see if my Indy can program them, I would hate to have to go to the Stealership.
Marc similar issue on my 06 going to take it to dealer and non dealer repair this weekend for estimates and fault codes.
Hope it's battery probably the servo valve body on mine...
Marc, I had something similar happen to our SLK a long time ago. It was a wheel speed sensor in our case. The faulty speed sensor disabled ABS and ESP for our 7hr trip. It could be something similar, maybe worth looking into before changing modules around. I was told that the sensor may have been knocked senseless by debris.
