AWD/PSM Failure Messages
Old 11-07-2011, 03:23 PM
Marc Gelefsky
Super Moderator
Marc Gelefsky's Avatar
Default AWD/PSM Failure Messages
Hey all,
Did some searching and did not fines anything definitive
Getting AWD and PSM Failure messages, have not scanned with Duramatiric yet but has anyone seen this? Some servo motor?
Or, could it just be my battery getting flaky, I think it's the original from 2004!
Also, when playing the radio with the car off for my Daughter I got the "Low battery" (or whatever the verbiage is,message) within 10 minutes.
Thanks!
Old 11-07-2011, 03:37 PM
911SLOW
Admin
911SLOW's Avatar
Forget durametric..and hunting down elusive error codes. Mudman is selling his "all sorted out" cayenne.
Old 11-07-2011, 03:41 PM
Marc Gelefsky
Super Moderator
I'll give him 60 bucks for it and a slighly worn PiGpen T-shirt
Old 11-07-2011, 04:16 PM
Slow Guy
Slow Guy's Avatar
I had a PCM/AWD error show up on the display on a trip down to Fla a couple of years ago. Turned out it was a known problem that required the replacement of xfer case potentiometer (at P of Orlando) and the xfer case Control Unit (which requires reprograming) at P of Nashville. The Control Unit couldn't be done in Orlando because I wasn't going to be there long enough for it to be delivered and the potentiometer part kept the error from popping up on return trip.
Fault Code was 2039 per invoice (Tech info sheet 19/10)
Mine was done under warranty (CPO).
Good luck.
Old 11-07-2011, 04:37 PM
Marc Gelefsky
Super Moderator
Good luck.
Thanks Bill, will check the fault code this evening.
Old 11-07-2011, 04:43 PM
JPP
JPP's Avatar
I'll up that to $65 and TWO slightly worn PPT's ...
Old 11-07-2011, 04:50 PM
mudman2
Moderator !x4
mudman2's Avatar
Ever had a strut go bad Mark ? What's your mileage and date of birth ?
Old 11-07-2011, 04:58 PM
Marc Gelefsky
Super Moderator
72K , Build date is around March-2004 I think. Air Suspension.
No strut issues but I think my Air Pump is ready for some service.
Old 11-07-2011, 05:10 PM
ArneeA
ArneeA's Avatar
You can get a replacement airpump from Wabco, the OES from these guys: http://www.arnottindustries.com/
I use their air struts for our X5 and they have held up well. *when* the Cayenne's air suspension goes, I will use their air springs.
Old 11-07-2011, 05:15 PM
Slow Guy
Slow Guy's Avatar
Thanks!
The radio msg is normal if you're using it while the engine is off. Just says the radio operation will shut off in a certain period to avoid battery drain. I get it all the time waiting for my wife at the airport.
Old 11-07-2011, 05:25 PM
Marc Gelefsky
Super Moderator
Arnott stuff is pretty good, I just replaced the fronts in the wifes Allroad with theirs.
Old 11-07-2011, 05:45 PM
Divot
Much missed
Divot's Avatar
I'll up it to a carton full of brand new PPTs.
Old 11-07-2011, 06:47 PM
mudman2
Moderator !x4
mudman2's Avatar
Early models have metal fatigue issues at the top near the airbag, that can go and destroy the bag
repair is possible dealers want to replace
Old 11-07-2011, 07:00 PM
Slow Guy
Slow Guy's Avatar
Should we take the new avatar to mean your fuel pump is repaired?
Old 11-07-2011, 07:02 PM
mudman2
Moderator !x4
mudman2's Avatar
Yes will be ready tomorrow, not flying yet tho haha
Quick Reply: AWD/PSM Failure Messages
