Help Needed: Hardwire DRL's for 2005 Cayenne
Old Oct 17, 2011 | 05:42 PM
RedDemon's Avatar
RedDemon
7th Gear
Default Help Needed: Hardwire DRL's for 2005 Cayenne
Hi All,
I'm planning to hardwire DRL's in my '05 Cayenne.
1. Is there a way to hardwire without going through the car's firewall (since the battery is located under the driver's seat)?
2. If going through the firewall (for the hardwire's), is there an existing location(s) where I do not have to drill anything and can just "run" the wire through?
Pictures would be most helpful!
Thanks all in advance!
Old Oct 17, 2011 | 07:27 PM
User 4221's Avatar
User 4221
I know you are looking to wire them, but the dealer can program this feature quickly through PIWIS system.
It will cost you a few $$ but easier and more reliable than a hard wire.
They can also flip the speedo to KPH if you are outside the US or UK.
Old Oct 17, 2011 | 08:38 PM
RedDemon's Avatar
RedDemon
7th Gear
hi scott,
thanks for the info.
how does the progamming work?
still looking to get some info. on how to get the wires from the engine throught the firewall into the battery area.....
thanks again!
Old Oct 18, 2011 | 12:36 AM
porschered951's Avatar
porschered951
I also installed DRL's on my 04 CS and ran the power and ground wires through the firewall and used a add-a-fuse to the fuse block(drivers side) for ignition power on and off. I think I used location 48 which is not used and available for adding a circuit. I also installed a black oval style rocker switch with small LED(LED on when DRL's are on) to the lower dash panel. This set up gave me the option to turn on or off the DRL's when the ignition is on. Must admit it took along time to figure out how to provide power to these lights. But now it's done the lights look great on the CS on or off.
Old Oct 18, 2011 | 04:09 AM
yeldogt's Avatar
yeldogt
I had the dealer program the lights when I took it in for another service -- they did not charge me to turn them on.
Old Oct 18, 2011 | 06:33 AM
bmbratz's Avatar
bmbratz
Hi sorry to jump on board what type of DRL's you got and also how big and what location have you fitted them in?
Old Oct 18, 2011 | 10:11 AM
bfly's Avatar
bfly
Which lights are used as the DTRL and what years is this possible?
Old Oct 18, 2011 | 12:54 PM
RedDemon's Avatar
RedDemon
7th Gear
porschered951, did you have to drill through the firewall at all? OR was there a location where you can just run the wire through directly (maybe near the steering column)?
i got the drl's from a company called: ijdmtoy.com. they come with a controller where it shuts them off with a 10 sec. delay and turns them on when the car is started. all you need to do is mount, run the wires and connet to + and - of battery.
my only need now is to figure how to run the wires throught the firewall (without drilling if possilble) to access the battery of the cayenne which is under the driver's seat.....
Old Oct 18, 2011 | 03:48 PM
deilenberger's Avatar
deilenberger
Curious how they know the engine is running or not.. but it would certainly be lots easier to run the wiring to the battery-jump point under the hood. On the drivers side under a plastic panel, clearly marked. No need to go through the firewall (unless you're obsessed with doing it that way.)
Old Oct 18, 2011 | 05:37 PM
RedDemon's Avatar
RedDemon
7th Gear
deilenberger, that's exactly what i was looking for. i'n not obsessed or do i really want to run the hardwire needlessly....hahah
i know the location you are talking about (battery jump point), but i didn't see were to "tap" in on that area.
do you have a pic or a diagram of how i can connect the + and - in that area.
thanks
Old Oct 18, 2011 | 06:41 PM
yeldogt's Avatar
yeldogt
Our we talking about the same thing -- The DRL on the CS are the headlights. With the xenons -- they just go on when you start the car.
The last thing I would want to do is mess around with any of the Porsche controllers or wires - they are bad enough without any help. And God only knows what could be screwed up.
The cars already have the capacity built in?
Old Oct 18, 2011 | 07:52 PM
RedDemon's Avatar
RedDemon
7th Gear
yeldogt, this is for a '05 base cayenne. it did not have DRL (strip/bar type) where the fog lights go (not in the headlight assemy itself) so i'm planning to install aftermarket ones.
i definetly don't want to play around (cutting into existing wires) with wires already there and that's why ,if i can figure out how to get to the battery (or another location with + and -) it would be most ideal.
Old Oct 18, 2011 | 08:13 PM
yeldogt's Avatar
yeldogt
So the base Cayenne did not come with fog lamps?
The fog lamps are not part of the Daytime Running Light system anyway.
Maybe what you are trying to do is to add lamps that attempt to replicate the strip lights found on other later models ....and use them for DRL?
That's something different
Old Oct 18, 2011 | 11:54 PM
porschered951
RedDemon, sent you a p/m
Old Oct 19, 2011 | 12:42 PM
RedDemon's Avatar
RedDemon
7th Gear
porschered 951, thanks. got your p/m and replied back....
yeldogt, nope, did not come with fog lamps. yes, trying to get drl's where the fog lamps would be. using a bar type rather than a strip type.
