Used 2004 CS, goes only 280miles
Old 08-23-2011, 03:01 PM
mcbit
mcbit's Avatar
I get about 19 - 23 mpg (us) average on both of mine, CTT gets longer runs GTS gets the shorter ones. I've never seen less than 500km (312m) to the tank...and if you want to know if I drive it you should ask my passengers!
Old 08-23-2011, 08:20 PM
Km1.8t
Km1.8t's Avatar
Tank size is 26 gallons and and if you do the math, that is a little over 15 mpg for 400 miles.
Old 08-24-2011, 01:18 AM
francars
francars's Avatar
This sounds about right. Maybe a few more miles more
Old 08-24-2011, 10:25 PM
Little Green
Little Green's Avatar
My tank has to be around 20 gallons. No way it is 26 gallons. My light comes on and when I fill up I put in about 18 and change
Old 08-25-2011, 12:09 AM
deilenberger
deilenberger's Avatar
Received 1,150 Likes on 763 Posts
From the owner's manual:
Total capacity approx. 26.4 gallons
(100 liters), including approx. 3 gallons
(12 liters) reserve
If I had to guess - one of your level sensors (there are two of them) is defective.
Old 08-25-2011, 08:26 AM
Little Green
Cool, it's about to go in for it's 60K service. One more thing to add to the list.
Old 08-25-2011, 09:27 AM
ltc
Super Moderator
Needs More Cowbell
ltc's Avatar
IIRC, there were 2 tanks offered, ~20 gal and ~26 gal.
IIRC2, the US only received the ~26 gal tanks.
Perhaps you got one of the RoW tanks in your P!g?
If so, that would make it almost as valuable as a 2007 US Cayenne...all of which came equipped with 55 gallon tanks.
Old 08-25-2011, 03:52 PM
seankrider
seankrider's Avatar
(12 liters) reserve
BTW, what on earth does that mean, "approx 3 gallons reserve"?? There's not really a reserve tank...right? It just means, when you get near 3 gallons, off goes the fuel light in the cluster.
I keep looking for the "RESERVE TANK" switch under the dash, to get me 30 more miles to the nearest gas station. Can't seem to find it...
Old 08-25-2011, 03:57 PM
mcbit
mcbit's Avatar
I'm RoW and can confirm having put at least 22 gallons in mine. My refuel light comes on every time at 80 km (50 miles)
Old 08-26-2011, 10:24 PM
thsung
thsung's Avatar
My fuel light comes on at 110 km.
Anyone try Rislone fuel injector cleaner or the oil treatment to increase fuel efficiency?
Old 08-26-2011, 11:36 PM
hahnmgh63
hahnmgh63's Avatar
You guys make me happy I got a CTTS as I get between 400~450 per tank, that is running it right down until the refuel light comes on then about another 5~10 miles. I do use a product known as Aces IV if any of you have ever heard of it but between my 4 cars I've only found it to increase mileage by about 1mpg. Mine drive is about 40% city & 60% highway but I usually do hit 80~100mph on the way home with a few spirited full throttle passes now & then when a passing lane opens up.
P.S. A '06 CTTS with the only mod being primary Cat bypasses & 55K miles.
Old 08-27-2011, 09:28 AM
yeldogt
yeldogt's Avatar
When my light comes on it does not take much more than 20 gallons to fill it up -- maybe the same engineer designed both the gas gauge and the brake pad warning that goes off too early.
My weekend place is about 80 miles away and I normally take the CS -- I may use the truck for a short errand during the week -- but it normally sits ........couple of short trips over the weekend. I normally need to fill it with about 19 Gallons after the second trip --- so I am getting 17 - 18 MPG.
Old 08-31-2011, 10:36 AM
thsung
thsung's Avatar
I just found that I can change my display to show in miles ... I get 10.7 miles per gallon (US). I probably hold the worst mpg on this forum (2004 CS).
Old 08-31-2011, 02:30 PM
wirunner
wirunner's Avatar
In my new home where I ride a crappy silver cho cho train to work stuffed with smelly people who don't know what deodorant is, my P!g is only used for "errands" and 100% city driving. The computer has not left 9.0 mpg in months, which consistently works out to about 200 miles per tank.
Hope this helps. I'm guessing you also do lots of short trips to achieve such good mileage.
Old 09-01-2011, 04:35 PM
RESP
RESP's Avatar
Just completed a 1200 km (720 mile) trip. Average fuel economy was 9.5 litres per 100 km (around 25 MPG).
This was at an average 65 mph, through (and over) the mountains with 3 people, 2 dogs and all our stuff.
Yes, it is a V-6, but I was easily able to pass everything I wanted to .
Quick Reply: Used 2004 CS, goes only 280miles
