Durametric Hacking and other cars codes? Please post if you have them!
#106
I agree with you completely Touareg as far as Vagcom (Ross-tech) goes. I have Durametric and Vagcom (3 other Audi's in the family). The Durametric is maybe to the point that Vagcom was over 10 years ago. Sometimes I will just use my Vagcom on the Cayenne as it is quicker and easier, but only on modules that I already know are common with the Touareg. I should just do a complete "Touareg" module scan with the Vagcom and see what Vagcom finds ('06 CTTS). I have the enthusiast version of the Durametric which has its own limits, where I can't program a module with Durametric I can usually do it with Vagcom, and more.
#107
Good news is that vagcom can read a lot modules on the 2011+ Cayenne
Transmission, HVAC, Airbag and so on... Not all data but its more powerfull then just generic OBD2
As for coding with Vagcom I might give it a try once I get new battery to see if I can code it in.
And yes I do own the durametric but usage is limited very limited at this time.
#108
Rennlist Small
Business Sponsor
Rennlist Small
Business Sponsor
http://www.porsche.com/all/media/pdf...yenne_pcna.pdf
Try page 126.
Pretty sure it is under settings, comfort.
Then it is unlock driver, unlock driver side, unlock all I think are the options.
Try page 126.
#109
touareg (and sup44), as requested...just received Durametric cable, running latest software. On my 2009 Cayenne GTS, here's what the Instrument Cluster codes page says:
Coding: 31204 Cayenne Instrument Cluster Coding
??xxx: Extra Options
+00 - No additional choices
+01 - Brake pad warning active
+02 - Seat belt warning active
+04 - Low washer fluid warning active
+16 - Radio-Navigation active
xx?xx: Country Setting
0 Germany
1 Europe
2 USA
3 Canada
4 Great Britain
5 Japan
6 Saudi Arabia
7 Australia
SO...since I wanted the silent cabin (seat belt chime off, no chime when key in and door open like Euro/Great Britain), I changed 31204 to 29104 (Like sup44 in earlier post).
Then I changed the units on the dash system display back to US units (miles, F, lbs, 12 hr, gallons, etc).
Beautiful silence, and red seat belt light does not display.
0 Germany
1 Europe
2 USA
3 Canada
4 Great Britain
5 Japan
6 Saudi Arabia
7 Australia
#110
Awesome! Beware if you take it in to a dealer…my local dealer loves to reset things and I have to specifically request that no one touch my European settings. I have the service advisor handwrite the message on whatever the work order is.
#112
I finally spent the time, after fixing some other issues, and did a full scan, using the suggested modules in the ini file with vag-com 17 and a newer cable I bough late last year, and it works great! Would love to do an A to Z scan of all numbers, not sure if possible, but it found quite a few modules. Since it pulled out DTC codes that not even my Porsche specific durametric tool pulls, I decided to be brave and reset DTC and do an adaptation.
Sunday,09,April,2017,09:29:49:64763
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 16.8.3.1 (x64)
Data version: 20161010 DS267.0
www.Ross-Tech.com
VIN: License Plate:
Chassis Type: 9P (9P - Porsche Cayenne)
Scan: 01 02 03 05 06 08 09 11 13 15 16 17 18 19 1C 22 29 32 34 36
37 39 3C 46 47 55 56 57 64 65 68 69 6C 6D 6E 75 76 77
VIN:
Address 02: Auto Trans Labels: 09D-927-750.lbl
Part No SW: 09D 927 750 JC HW: 09D 927 750 JC
Component: AL 750 6A 1322
Revision: 00H79000 Serial number:
Coding: 0045096
Shop #: WSC 128452 000 00000
VCID: 78FE6112082FB08284-5122
No fault code found.
Address 03: ABS Brakes Labels: 7L0-907-379-MK25E1.clb
Part No SW: 7L0 907 379 P HW: 7L0 614 517 C
Component: ESP ALLRAD MK25E1 0304
Revision: 00H53001
Coding: 0012742
Shop #: WSC 31414 790 00001
VCID: 4682DFEA355B1672C6-8012
1 Fault Found:
01314 - Engine Control Module
013 - Check DTC Memory - Intermittent
Freeze Frame:
Fault Status: 00101101
Fault Priority: 2
Fault Frequency: 2
Reset counter: 173
Mileage: 94459 km
Time Indication: 0
Freeze Frame:
Count: 19712
Count: 12289
Count: 8196
Count: 261
Address 05: Acc/Start Auth. Labels: 3D0-909-13x-05.lbl
Part No SW: 3D0 909 137 G HW: 3D0 909 137 G
Component: 1J Kessy 6850
Revision: 00H22070 Serial number: VWZ3Z0H7798054
Coding: 0704673
VCID: 2B548E5E8EF9CB1A39-807E
Subsystem 1 - Part No: XXXXXXXXXXX
Component: ELV XXXX
1 Fault Found:
00181 - Access/Start Authorization Antenna (in Rear bumper) (R136)
001 - Upper Limit Exceeded
Freeze Frame:
Fault Status: 01100001
Fault Priority: 4
Fault Frequency: 6
Reset counter: 91
Time Indication: 0
Date: 2000.00.00
Time: 10:50:00
Address 06: Seat Mem. Pass Labels: None
Part No: 7L0 959 760
Component: Sitzverstellung 0701
Shop #: WSC 00000 000 00000
VCID: 77FC622E0231BFFA8D-8022
Address 08: Auto HVAC Labels: 7L6-907-040.clb
Part No: 7L5 907 040 BT
Component: Klima - SG R/L 4325
Coding: 0001030
VCID: 020A03FA59F3EA52AA-8056
Address 09: Cent. Elect. Labels: 7Lx-937-049-V2.clb
Part No SW: 7L5 937 049 AA HW: 7L5 937 049 AA
Component: J519 1802
Revision: -2004--- Serial number: --------------
Coding: F2000002082A5C000000000000000000
VCID: 7AFA7B1A3123A292F2-802E
1 Fault Found:
00061 - Footwell Lights
011 - Open Circuit - Intermittent
Address 15: Airbags Labels: 7L0-959-655.lbl
Part No SW: 7L0 959 655 HW: 7L0 959 655
Component: J234 3E VW8T 0250
Revision: 92012025 Serial number: 0039P00624PV
Coding: 0013125
Shop #: WSC 01636 552 00000
Subsystem 1 - Part No: 659 256 .50 .10
Component: BF-Gewichtsens.
Subsystem 2 - Serial number:
1 Fault Found:
01312 - Powertrain Data Bus
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 2
Fault Frequency: 18
Reset counter: 255
Time Indication: 0
Address 16: Steering wheel Labels: None
Part No: 7L5 953 549 D
Component: Lenks‰ulenmodul 1701
Coding: 0001312
VCID: 3F8CCA0E6A8147BA85-806A
Address 19: CAN Gateway Labels: None
Part No: 7L5 907 530 E
Component: Gateway CAN/CAN E1 2500
Serial number: ˇˇˇˇˇˇˇˇˇˇ
VCID: 3560A82658BD8DEA5F-8060
1 Fault Found:
00459 - Control Module for Display and Input; Front (J523)
Address 34: Level Control Labels: 7Lx-907-553-34.clb
Part No: 7L0 907 553 J
Component: LUFTFDR.-CDC- 3C3P1 3125
Coding: 0015511
VCID: 3A7ABB1A71A36292B2-806E
Address 36: Seat Mem. Drvr Labels: None
Address 65: Tire Pressure Labels: None
Part No SW: 7L5 907 273 E HW: 7L5 907 273 E
Component: J0502 RDK 0007
Revision: 00006007 Serial number: 00000700018197
Coding: AC17800000
VCID: 3978A41674A5698ABB-806C
1 Fault Found:
02214 - Tire Pressure Warning
000 - - - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 1
Fault Frequency: 4
Reset counter: 191
Mileage: 95472 km
Time Indication: 0
Date: 2000.00.00
Time: 08:46:38
Freeze Frame:
(no units): 77.0
Address 6C: Back-up Cam. Labels: None
VCID: 55A008A6B8FDADEABF-8000
No Faults Found
or DTCs not supported by controller
or a communication error occurred
Address 6D: Trunk Elect. Labels: 7L6-959-107.clb
Part No SW: 7L5 959 107 HW: 7L5 959 107
Component: J605 HECKKLAPPE 0101
Revision: --002--- Serial number: --------058153
Coding: 2121210
Address 76: Park Assist Labels: Redir Fail!
Part No: 7L5 919 283 B
Component: 00 Einparkhilfe 0201
End-------------------------(Elapsed Time: 10:28)--------------------------
www.Ross-Tech.com
VIN: License Plate:
VIN:
Coding: 0045096
Revision: 00H53001
Coding: 0012742
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Reset counter: 173
Mileage: 94459 km
Time Indication: 0
Freeze Frame:
Count: 19712
Count: 12289
Count: 8196
Count: 261
Coding: 0704673
Component: ELV XXXX
1 Fault Found:
Freeze Frame:
Fault Priority: 4
Fault Frequency: 6
Reset counter: 91
Time Indication: 0
Date: 2000.00.00
Time: 10:50:00
Coding: 0001030
1 Fault Found:
Coding: 0013125
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 18
Reset counter: 255
Time Indication: 0
Coding: 0001312
1 Fault Found:
Coding: 0015511
Coding: AC17800000
1 Fault Found:
Freeze Frame:
Fault Priority: 1
Fault Frequency: 4
Reset counter: 191
Mileage: 95472 km
Time Indication: 0
Date: 2000.00.00
Time: 08:46:38
Freeze Frame:
(no units): 77.0
No Faults Found
Coding: 2121210
#113
So with the vag-com I went and cleared all the DTCs, no problems.
I find it interesting that module 6C was found? I don't have a back up camera and have PCM 3.0, hmm, need to check if there are any adaptations in there.
The big one was at address 9, central electric, Durametric could never do anything with this for me, so now I am able to code and adapt this module.
What is this? 3 to 5 soft touch flashing?
Call me crazy, let's test and save:
And the results:
It works! Been wanting this for like 6 years now since I had done it on my Touareg
![](https://cimg0.ibsrv.net/gimg/rennlist.com-vbulletin/650x459/adaptation_turn_signal_5e5121b7aacdffa078b4587e5b5ad73efb536884.png)
![](https://cimg1.ibsrv.net/gimg/rennlist.com-vbulletin/657x470/adaptation_turn_signal_verify_3d58343850e19fb40047c56fe16b06206ce05be8.png)
And the results:
![](https://cimg2.ibsrv.net/gimg/rennlist.com-vbulletin/624x460/adaptation_turn_signal_post_0565018f4c2d96d7c87e42c2fc4f1e999ed57294.png)
#114
So the central electric supports long coding, something on the newer cars from the last 10 or so years I am not familiar with. Others have been able to code auto headlight feature with a switch, I on my 957 have not.
I Need to take a look at the 7Lx-937-049-V2.clb label file, as my interest with the vag-com has been re-peaked. (Edit, this file has been encrypted for prevention of theft of effort)
Since our cars have a mix of porsche and VAG components, not everything will probably ever be supported, but I like this so far.
#115
I am now ready to turn on some other options (flashing emergency brakes anyone?):
I think I got it now this is from ross-tech on the same module in the Touareg T2 and newer I guess, looking at my coding from above, things seem to match up on my Cayenne, but no promises here:
I think I can enable auto lights on the 957s now with vag-com!
Byte 4 with Bit 1 and 5
Byte 00 Bit 0 Daytime Running Lights
Byte 00 Bit 1 Country/Area North America
Byte 00 Bit 2
Byte 00 Bit 3 Rear Fog Disabled in Off-Road Mode
Byte 00 Bit 4
Byte 00 Bit 5 Front Fog Lights
Byte 00 Bit 6 Rear Fog Lights
Byte 00 Bit 7 High Beam with Assistance Driving Light
Byte 01
Byte 02 Bit 0 Halogen Headlights (Rest of World)
Byte 02 Bit 1 Halogen Headlights (North America)
Byte 02 Bit 2 Xenon Headlights (Rest of World)
Byte 02 Bit 3 Xenon Headlights (North America)
Byte 02 Bit 4
Byte 02 Bit 5
Byte 02 Bit 6
Byte 02 Bit 7
Byte 03
Byte 04 Bit 0 Assistance Driving Light
Byte 04 Bit 1 Coming-Home
Byte 04 Bit 2 Garage/Cinema Light
Byte 04 Bit 3 Comfort/Tip Blinking
Byte 04 Bit 4 Emergency Brake Blinking
Byte 04 Bit 5 Comfort Interior Lightning
Byte 04 Bit 6
Byte 04 Bit 7
Byte 05 Bit 0
Byte 05 Bit 1 Hydraulic Nozzles for Headlight Washers
Byte 05 Bit 2 Electric Fuel Pump for FSI Engines
Byte 05 Bit 3 Electric Fuel Pump for Gasoline Engines (NOT FSI)
Byte 05 Bit 4 Electric Fuel Pump for Auxiliary Heating
Byte 05 Bit 5 Wake-Up Function (for Air Suspension)
Byte 05 Bit 6 Anti-Theft Protected Headlights
Byte 05 Bit 7
Byte 06 Bit 0 Second Battery Network
Byte 06 Bit 1 Second Battery
Byte 06 Bit 2 Generator Port
Byte 06 Bit 3 Seat Heating
Byte 06 Bit 4 Load Management
Byte 06 Bit 5 Load Consumer
Byte 06 Bit 6 Generator Port Idle
Byte 06 Bit 7
Byte 07
Byte 08
Byte 09
Byte 10
Byte 11
Byte 12
Byte 13
Byte 14
Byte 15
Found some other options for newer touaregs:
09-Cent. Elect. - Tear wipe, Lights On Warning, Various light changes
Security code: 20113
[Coding - 07] -> Long Coding Helper:
Byte 1 Bit 3 – Tear Wiping On or Off
Byte 2 Bit 6 – Dim Wink On or Off
Byte 3
Bit 2 – LED remain the same brightness (1 = Active)
Bit 7 – Turn off LED strip with indicator (1 = Active)
Byte 5
Bit 3 - Set to 0 to disable "lights are on" warning when you open the door
Byte 10 Bit 3 – Enable/Disable amber corner lights in front
Byte 00 Bit 2
Byte 00 Bit 4
Byte 01
Byte 02 Bit 4
Byte 02 Bit 5
Byte 02 Bit 6
Byte 02 Bit 7
Byte 03
Byte 04 Bit 6
Byte 04 Bit 7
Byte 05 Bit 0
Byte 05 Bit 7
Byte 06 Bit 7
Byte 07
Byte 08
Byte 09
Byte 10
Byte 11
Byte 12
Byte 13
Byte 14
Byte 15
Byte 3
Byte 5
#116
I am happy to report, I was able to change the coding, and allow the bits that look to switch on the comfort light and auto headlight switch enablement on.
What this means, is my auto switch I need to repurchase should work, and my delay option is now in the MFI:
![](https://cimg6.ibsrv.net/gimg/rennlist.com-vbulletin/1502x668/screen_shot_2017_04_12_at_3_24_32_pm_e06c59c692cf4fd2aa4be00f652f81361e5c0fb0.png)
![](https://cimg1.ibsrv.net/gimg/rennlist.com-vbulletin/2000x1481/imag3613_32e76e3abb9f4355c69a0ac58e662956f76dc158.jpg)
#117
I am not done digging yet, after this plan to look into getting the flashing brake lights.
Don;t really want flat spots on my tires though to test:
#118
Supercharged
Sorry if you covered this, but what did you do to the Vag-com/VCDS/Ross-Tech cable to get this to work? I have one (not a knock off) and tried hooking it up, but it was not happy. Would love to make use of my cable and s/w if possible. Thanks.
#119
I had a cable from 2004 or so, and that was too old to work, I upgraded to the latest cable last year, and that does multiple bus architectures.
Depends on how old your cable is, I think if it is more than 10 years, like my old one you needed a newer cable.
If you have the older cayenne, you can just use the durametric.
Even though I no longer have any VW audi stuff, decided I wanted a newer cable to mess with the 957 cayenne.
#120
Just bought a used switch for $15 shipped on ebay, happy about that. Should have it friday.
7L5.941.531C search that part, more cheaper listing than the 955 part number.
