Towing a UHaul Car Trailer
Well I decided to rent a UHaul trailer to tow my RSA to its first Auto-X. Made the reservation, which the UHaul online system which then redirects the reservation to the closest pick-up point (not necessarily the one you designate). Well, I though the experience was still worth the 45 min one way pick-up. The staff was friendly and helpful hooking up the trailer. They also helped me check all the lights and I was surprised that despite this being an LED trailer, there did not seem a problem with the lights or the display inside the Cayenne. Even the secondary turn indicator on the instrument panel worked. Cosmetically, the trailer was dirty and looked like a POS (I mean big POS).
Here is a picture of the "Rig":
Loading on these trailers is surprisingly far forward so I figured that this would be a good match for a rear engined car. I even measured the tongue weight of the loaded trailer with a bathroom scale and a cantilever set-up and it came out to a whooping 600 lbs! (but was still within limits).
I am not sure how anybody would ever be able to tow a front engine car with one of these. The tongue weight most be monstrous.
The GTS pulled like a charm and I kept within the speed limits. The empty trailer weighed about 2000 lbs and it felt heavy. The whole process felt a lot smoother with the car on it. Ample power with the GTS and no problems braking for the occasional idiot trying to squeeze in front of me coming up an on-ramp.
General impressions:
- I checked the brake lights again at home and "of course" the brake lights didn't work. I was pretty upset about this since the UHaul staff stated that they worked but there was absolutely nothing that could be done. Seems that UHaul LED trailers don't work with Cayennes.
- The trailer was dirty, rusty and looked like a POS
- The ramps are too steep to load a 911 without an ample supply of wood to lengthen it.
- There is not enough clearance for the front spoiler so I had to add a piece of wood to raise the front of the car:
In summary: An interesting experience but will not do it again because I don't trust the mechanicals of the trailer 100% and the LED brake light issue. I will try Hecht Trailers next time or simply buy my own.
Super Moderator
Needs More Cowbell
Needs More Cowbell
To get the led lights to work on the Cayenne you need an adapter with resistors built in to it.
Adapter
Adapter
Also, it won't work if you have a trailer equipped with a 7 pin connector (not a 4-5, which are usually smaller trailers or surge brake trailers)
Or I could be wrong ...
Super Moderator
Needs More Cowbell
Needs More Cowbell
Super Moderator
Needs More Cowbell
Needs More Cowbell
... still learning
Super Moderator
Needs More Cowbell
Needs More Cowbell
Super Moderator
Needs More Cowbell
Needs More Cowbell
Best to not go there...let sleeping dogs lie...have soome respect for the deceased...both Larry and his Cayenne were part of a murder/suicide, at least that's what I've heard, since the court documents were sealed after his death.
The first 3 events we attended after taking delivery on my wife's Cayenne was with the help of UHAUL...
The LED lights, the weight, the condition of the trailers... etc What a nightmare!
After the first trip to LRP (same case NO lights) I picked up the adapter w/resister from Suncoast. 2nd trip (even with wood ramps) the HUGE standing ribs left a wonderful crease down the underside of the trunk, broke the body skirt and really P _ _ _ _ d me off.
3rd & Final time was not any better as the weight caused the truck to handle like CRAP!
Finally, went out an bought a Aluminum trailer....
