Winshield Wiper fluid warning light on frequently!
Washer Fluid coming on several times despite filling it with Prestone. I use it as usual, but not excessively. No leaks observed. Will take to dealer and let you guys know.
Super Moderator
Needs More Cowbell
Needs More Cowbell
If it's not corroded contacts for the fluid level sensor, you will likely get a new tank.
Can I interest you in some new horns while you're in there?
Super Moderator
Needs More Cowbell
Needs More Cowbell
BTW, speaking of horns and moisture, have you checked to see how much washer fluid might be leaking from the front bumper headlight washers ?
The V8 Porschephile
The V8 Porschephile
It might be a good time to remind some of you who live near the northern belt to drain/re-fill the windshield washer fluid inside the reservoir.
Most of us rarely use our w/w fluid during summer months. After a long and hot summer, the alcohol content within the reservoir diminishes somewhat and makes the liquid less effective on sub-zero temps.
Around this time of the year, I like to use an industrial syringe and draw the liquid out of the reservoir and replenish it with new fluid afterwards.
That or just put in some full concentrate winter fluid. I like 20/10
