Burmester . . . yay or nay?
What's the verdict on the Burmester upgrade? Spec-ing my Cayenne Turbo. Wondering if I should / need to upgrade my sound system from the Bose.
http://www.6speedonline.com/forums/p...rmester-2.html
Spent a few minutes on a Pana that had a Burmester with a very good quality Cd of mine (none of the Cayenne's on the lot had it)....mind blowing. I will custom order one with it.
If you're going to mostly listen to Satellite Radio and MP3s don't bother.
Seems like most of you highly recommend the Burmester. However, I just wanna add that 99% of my music will be digital (via iPod). Will the Burmester still make that big a difference?
I know I should make the decision already and stop wasting you guys' time on this, but I'm confused as I thought it'd be a no brainer nay, but seeing so many yays, I'm lost. Finally, as much as I would like to go try it out, not available here to try, so I gotta go by your suggestions. Thanks again!
Super Moderator
Needs More Cowbell
Needs More Cowbell
Larry (R.I.P) would recommend the Burmeister ...
I think he knew a little bit about the audio systems and the guys who designed them...
Probably a lot of audiophiles on here will have the same input. You will lose a great deal of the benefit if you primarily listen to compressed music as the source. If your ipod is uncompressed downloads and/or CD burned to hard drive, or you will use CD's, then you have a harder choice to make. If your sources are compressed, might be better off using the $ for something you will enjoy more.
For the record, we listen to uncompressed music and ordered Burmester.
