04 Cayenn S resets before start - ideas?
Long time lurker now posting in search of wisdom...
My 04 S is showing its age and like any good car out of warranty - falling apart.
The pipes and cardan shaft were easy enough to sort but this problem has me stumped:
About 20% of the time when trying to start the Cayenne lately it will balk - starter will not turn over and all goes dim. Sometimes two or three times in a row. The car resets itself (clock to 0:00, all settings to default etc) and then will start. The AC takes a minute or two to come on as well.
Really frustrating..any idea where to start on this?
your $.02 is appreciated.
Thanks!
tried to search this but did not find anything - point me in the right direction if it has been discussed before
Thanks!
A failing battery can do this in hot weather -- also a replacement battery with lower CCA can do this in hot weather.
How old is the the battery. Did you recently put an aftermarket battery in the car?Nothing wrong with an aftermarket battery as long as its correct.
You could also have a bad connection in the starter circut or a failing starter that is pulling too many amps. A simple charging/ starter load test should be able to tell if it is on of the above.
Sounds like you have the two battery option (since you're getting it started; plus the AC coming on later symptom). The primary battery under the driver's seat has checked out, but perhaps replacing both would be wise. The aux is under the sub in the trunk.
My old beta used to do the exact same thing, but I never bothered replacing the battery. Actually, your picture looks like my old beta - did you buy that recently??
10 to 1 it was the primary battery...my Varga gave out after 6 years but the car would start on the auxiliary after 2 or 3 turns on the key (must be a relay in there somewhere)....
sourcing the battery was no problem - getting the 10mm triple square is another story.
Autozone, Pep Boys, Advance, Sears all no go - even the 3 local NAPA stores don't carry it.
Ordered a decent set on-line - so much for supporting local shops and having an impromptu Sunday afternoon wrenching session with your car...
yeah....even my battery supplier didn't have one....had to bring it home and install it myself....that tool came in handy for something I can't remember
